Step 11Glass the Joint
The 4 oz cloth sucks everything flat and will let me sand without cutting the weave of the heavy cloth underneath. SCANDAL!! many surfboards are made weak by sanding the cloth. Possibly this board broke for that reason. Actually this board looks like it got stomped by a gorilla while propped on sawhorses.
I pieced this layout from odd scraps because it's a deck and is supposed to be rough. My biggest piece of 4 oz went on top. Exposed edges of cloth stand up and make ridges when soaked with resin. So put your small pieces under your bigger pieces so you only get one ragged edge.
Wrap the glass around the rails (edges) of the board. Tape the glass to the underside to hold it tight and make sure it doesn't fall down.
SKILL TRICK:
To wrap a tight bend without the cloth lifting, cut the cloth at a 45 DEGREE ANGLE TO THE WEAVE.
Then the fibers cross the bend at gentle angles and the cloth will lay onto a much tighter bend. Try it and see. I wish I'd known about this a long time ago.
comment
Add Comment
Add Comment
