Fix a Broken Pin on an IC Chip
7,148
50
5
Published
Introduction: Fix a Broken Pin on an IC Chip
About: Most of my instructables will be tutorials for Atmel microcontrollers, Arduino, or Raspberrypi. I try to show concepts that you can use in your own programs by creating simple programs and circuits to illus...
Have you ever broken a pin on an IC chip?
  • Don't throw it away.
  • Don't pay a ridiculous price for overnight shipping.
  • Don't put your project on hold for 2-4 days for slow shipping.
Why not try to fix the broken pin? You have nothing to lose. I accidentally bent a pin on my Attiny85 chip and when I tried to straighten it it broke. This instructable shows how I fixed it.
Step 1: Soldering on the New Pin
You need ways to hold both the wire and the chip securely. A couple vices or a helping hands will work.
Cut a length of 22 gauge wire, mine was about two inches long.
Strip off about 1/2 inch of insulation and carefully lay the wire across what is left of the pin.
Solder the wire onto the broken pin.
Remove the chip and the wire from their holders, and cut the wire to the same length as the other pins.
Step 2: Finishing Up and Using the Chip
Carefully bend the pin so it will fit into a perfboard.
Do this before trying to put the chip into a socket.
Step 3:
It would be very hard to solder to the new pin without melting the solder holding the pin to the chip.
For this reason I recommend putting the chip in a socket instead of trying to solder it into your project.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    5 Comments
    Thank you KTELL KTELLI for posting a link to this instructable on http://robot4pro.blogspot.com/2015/08/fix-broken-pin-on-ic-chip.html
    very clever,..i did the same thing..
    For what I see looks like your very close to having a short.
    I have tested the chip, it works. It does look close, but no short
    If you like this instructable please vote for it in the soldering contest.
