iImage Information
A common failure of these excellent dustbins/trashcans is that the foot pedal's plastic cover snaps off. This instructable will show you how you can fix the cover in just a few minutes - and it will be stronger than new!
You'll need:
2-part epoxy glue e.g. Araldite.
Methylated spirits or white spirit or sandpaper.
An elastic band or some bicycle inner tube.
Step 1Clean parts and prepare adhesive
iImage Information
Turn the pedal cap upside down and identify where the plastic has snapped off. If your pedal cap looks like this the job is easy. Use alcohol or other solvent to clean the four circular sections and the corresponding snapped remnants on the metal pedal - or lightly abrade with sandpaper. Do no remove the plastic peg remnants on bin pedal - the glue will need to adhere to these!
Mix up a teaspoonful of 2-part adhesive and place equal portions into the 4 plastic circular sections.
L
To be serious, I find Wilco' 2-part is pretty good, but I don't ask much of it.
L
