Remove these ads by
Signing UpStep 1Open the case and examine the circuit board
Beginning from the right side and moving to the left, you see the battery leads from the switches and the red "on" LED. One of the resistors limits the current to the LED. The other provides the correct bias current to the transistor (the black object at the lower right corner of the circuit board). Transformers cannot work with direct current. The transistor switches on and off rapidly to create a rising and falling voltage for the transformer to step up. Next comes the transformer. My friend's unit has only one capacitor for storage of the charge while it builds up to the maximum charge of the capacitor. This unit has two capacitors and four diodes. I did not check it out thoroughly, but I believe the diodes and the capacitors make a voltage multiplier. At the far left of the circuit board are four bleeder resistors to dissipate the charge on the capacitors when one is finished using the swatter. The bare wires are the high voltage wires to the grid wires in the yellow swatter frame.
With this help I'm sure to be back at the top of my game again in no time.
Thanks so much... .
(I know as I have once used one to drive a home-made high voltage transformer/stun gun.
I hate to suggest anything to such a well put together piece, but....where you speak of a heat sink (and I agree 100 %) several things work if you cannot find the "real thing" as you show.
I was unable to get them, even at my local Radio(less) Shack....so I sent off to some mailorder house like American Science and Surplus or some such place, and ordered up 3 hemostats. These things are GREAT. they can hold pieces, wires together and be used as a heat sink at the same time.
That's kind of how I created an extension for the switch on the back of the "hacked" Radio Shack voice recorder. :-)
Yes, I have found all kinds of uses for hemostats when soldering....they can make a great "base" for holding pieces upright etc.
and maybe help someone get his flyswatter working again.
Or if I ever come across a non-working one on one of my, um, outings.....I have this to fall back on :-)
