Fix a stripped wire on your headphones
I bought a nice pair of headphones a few months back, and noticed recently that plastic has started pulling away from the joints, exposing the wires.  Before it got any worse, I went to Noah to ask his advice.  Turns out, he was having a similar problem and had a fantastic suggestion: Plasti Dip!
With those two words, I set off of gathering the vast amounts of materials that would be needed to fix our headphones.  All one item.
(This all seems very self explanatory, but I've ran into many people who've never heard of this product or what it does.  It's for that reason that I'm putting this here!)
Step 1Materials
Materials
Plasti Dip
Seriously...that's all you really need.  I found types of Liquid Electrical Tape type products when searching for this, but I haven't tested any of them so I can't really recommend them.
If you want to take things the extra step:
Bowl (you wouldn't mind throwing away)
Toothpick, Small Stick or Small Brush (that you wouldn't mind throwing away)
32 comments
Apr 2, 2010. 4:14 PMKlappstuhl says:
Great Idea, looks very biological/alive now! Like one of the biopads from the movie Existence :D
Jun 2, 2011. 6:53 AMOnline Mastering says:
Excellent Post!
This is a very common problem and there aren't many solutions around :)
Good Share
Feb 27, 2011. 12:29 PMonlinemastering says:
When you have headphones of that calibre it;s definietly worth repairing, they are NOT cheap ! When soldering it is nice to have good quality tools, good wire cutters and strippers make life much easier. Also a clean soldering iron bit and solder with a lower melting point all help make the job easier. cheers
SafeandSound Mastering
online mastering
Apr 1, 2010. 7:04 AMxiao_haozi says:
 Great work.  I have always taken the cut and resolder approach but it's not such a fun task when you split at a Y like that or so close to a dongle... usually try to open the Y joint and repair inside it.  This seems much more headache free.
What about reusability of the remaining plasti-grip solution?  The excess that you poured into the bowl, can that be reused or is that lost to the project?
Apr 2, 2010. 9:08 AMxiao_haozi says:
 Ah good to hear it's essentially reusable then...
What to use the rest for? Well I think my problem is the opposite, I can't decide what I shouldn't try to use it for.
I plan to use some for the bottom of custom electronic cases as an anti-sort of finish.  Also wanted to try it out as an alternative to expensive powder coating...
Apr 3, 2010. 8:10 AMxiao_haozi says:
 Will do!
Apr 1, 2010. 10:50 PMPunkguyta says:
 I agree with you completely.
Apr 2, 2010. 6:37 PMjtmcdole says:
 Great job!  I'll have to remember this the next time anything I own starts to strip away.
Apr 1, 2010. 8:32 AMchicapalta says:
Cool! Wondering how to do this if the wire is stripped close to the head phone, tho? Would be more difficult to dip without compromising the cushiony ear part.
Apr 2, 2010. 7:37 AMsmrp1984 says:
GREAT INSTRUCTABLE
I have a pair of ear bud type headphones that got a slice in the outer jacket of the cord "didn't touch the conductors". The wire was so thin I was worried it would break, so I decided to use my Liquid Electrical Tape "great stuff, everyone should have a can of it" works like the plasti-dip but is vinyl based and comes in a can w/ brush attached like rubber cement. The fix was flawless and I saved a $60 pair of ear buds. I'm sure the plaits-dip works great but if you already have liquid electrical tape around it will do the job just as well.
Mar 27, 2010. 1:29 PMGroxx says:
 I've got the same headphones, and I've got the exact same problem.  The other option is to send it in to Grado, they apparently do effectively any repair for $30 after it's out of warranty (I think a year).  I'll probably end up dipping it insteadnow that I've seen it done, thanks!
Mar 24, 2010. 10:11 PMTezcumpapa says:
Thanks!  I am hard on my headphones and need to replace them every couple of months.  This ought to help!  Thanks again!
Mar 23, 2010. 6:26 PMClonebear says:
Could you 'paint' this stuff on? Because I've got a couple of Gamecube Controllers that the wire is pulling out of the controller, and I  was wondering if I  could just paint some of this stuff on.
Mar 23, 2010. 9:05 AMyorickdemunnik says:
 Nice job, but I think I'd used Sugru.
Mar 23, 2010. 2:26 PMnoahw says:
I don't know if that would be an improvement...the liquid form of Plasti-Dip is actually pretty perfect for covering the wires.  I don't see how you'd use the clay-like state of Sugru to ever get such an even nice coating.  But, by all means...
Mar 23, 2010. 3:12 PMyorickdemunnik says:
 Did you ever use it?
Mar 23, 2010. 4:33 PMnoahw says:
Uh no, I'm just guessing looking at the pictures of the stuff.
Mar 24, 2010. 6:46 AMyorickdemunnik says:
 Sugru is moldable like clay but when it cures it's like durable rubber. You should buy some ! :) But as I said nice job!!
Mar 23, 2010. 11:39 AMbaneat says:
Seriously how did you strip the Y on a pair of grados? Mine are extremely sturdy there.
Mar 23, 2010. 2:27 PMnoahw says:
The Y isn't stripped entirely, just the plastic housing that covers the wires is.  It's just press fit in there, and on my pair, which is at least 10 years old at this point, it seemed to come away from the Y hard plastic housing quite easily actually.
Mar 22, 2010. 4:32 PMSinAmos says:
Nice covert advertising.  Looks good.
Mar 22, 2010. 2:56 PMCartermarquis says:
Looking at the "Y" on my SR-80's, it looks like it would be pretty prone to strip like yours did.  Great fix.
Mar 22, 2010. 2:27 PMitsachen says:
 Grado SR80's. Very nicee
Mar 22, 2010. 2:17 PMjeff-o says:
Great idea!  It's been filed away in my brain-vault.
Mar 22, 2010. 12:33 PMlemonie says:
I must get some of that stuff.
I bet is stinks?
L
Mar 22, 2010. 2:00 PMscoochmaroo says:
You know it!  I love this stuff to coat the handles of my scissors too,   Makes like a comfort grip!
Mar 22, 2010. 11:44 AMgmjhowe says:
 Nice, the final thing does not look too shabby!
Great phones btw!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
210
Author:StumpChunkman
