3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fix a stuck pixel on an LCD monitor
Step 4Third method: tapping monitor
This final method works but can easily create more stuck pixels or even do some real damage so be careful. First you need to display a dark color / image over your stuck pixel. (Make sure it's really showing a dark color / image and not just a blank signal) Take the back of your stylus, or another small, blunt object, and lightly tap on the stuck pixel. You should briefly see a white spot where you tapped. If not, then tap a little harder. Keep tapping, each time tapping a little harder. This should only take about 5-10 taps. This should correct the stuck pixel. Be careful thought, because doing it too many times may cause damage to your monitor.
I believe that the reason this works is the same as method 2.
3 comments
Jul 7, 2011. 9:53 AMviolentorchid says:
I haven't really ever had a stuck pixel. Must be all the shaking and stuff. Treat you screen like an etch-a-sketch is what I got out of this.
Apr 29, 2011. 3:12 PMdoofusrocker says:
i just named mine "Pete" and left him alone.
May 16, 2011. 10:54 AMWin Guy says:
I have two named "Joe" and "Phil".
Sep 30, 2009. 1:07 PMHycro says:
I tried the flashing colours, and it did nothing, then I tried this method, it did nothing, then I thought what if I just lightly pushed on it instead of tapped, and pushed successively harder?? and it worked perfectly!! Thank you for the information! I finally got rid of the "blue dot of mystery"
Nov 4, 2009. 7:29 PMbwpatton1 says:
Cool, I just got a laptop for my birthday and it has a "Red dot of mystery"          :( soo annoying, I might have to try this.....hmm........
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Einsteins Circuitry
I love computer programming and hardware hacking, robotics, and building stuff. This is my website, [http://www.voidingwarranties.com/].
