loading
I did this at TechShop Menlo Park's automotive area! www.techshop.com
Cleaning your carburetor is only a part of getting the fuel to flow on your outboard motor. For proper maintenance you must clean out and care for the fuel hose system, inlet, outlet and fuel filter.
Step 1: Remove the Fuel Filter Bowl
Carefully pull out the glass bowl nut and remove the fuel filter containing the sintered fuel element. Use B12 or other spray cleaner of your choice to flush from the inside out.
Step 2: Blast the Fuel Outlet
Back-flush the fuel outlet that leads to the carburetor.
Step 3: Hose Flush
Remove the inlet hose clamp and flush thoroughly with B12 spray.
Step 4: Reattach the Fuel Filter
Gently place the glass fuel cup containing the filter element and secure it with the nut.
Step 5: Reattach Fuel Inlet Hose
Screw in the hose clamp and reattach the other end to the carburetor.
Step 6: Hook Up the Fuel Connector
You gas can containing the proper fresh gas/oil mixture can now be connected to your motor.
Step 7: Start Your Motor!
Pray to Sea Gods and all nautical creatures that your motor will now start.
Enjoy sailing but watch out for Mermaids. Their sweet melodies will freeze up your motor once again!
About This Instructable
3,957views
5favorites
License:
More by Miss Cabbit:How to clean out a rusty gas tank and replace oil on a moped Making a sink cover for a house boat Making a collapsible dog ramp for a houseboat
Add instructable to:
