Fix the Dell OLOD (Orange Light of Death)
Published
Introduction: Fix the Dell OLOD (Orange Light of Death)
If you have a Dell pc that won't turn on, Chances are that you have a power supply problem. Most of the time the power light will be flashing
Orange.
Step By Step:
(Disconnect all cables, Inc the power)
1. Open the case of your Dell Pc
2. On the power supply box (top right) find the GREEN wire
(The green wire will almost always be the power switch on all Pc's)
3. Cut it at around the middle
4. Strip Both Ends
5.Find a long enough piece of wire that will reach to the front of the pc
6. Solder the GREEN wires back together but putting your seperate peice of wire inbetween them
7. Tidy them up with zip ties and shrink tubing (Electrical Tape if not)
8. Plug the power cable into the pc
9. Hold the wire onto the chassis of the pc
10. If the fans start at full speed, press the power button and let the wire off
11. your pc should be running as normal.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    65 Comments
    Holy *bleep* it worked! Way to go curtisg!! If it helps anyone I used a three-way connector (got it from the automotive section in Walmart) on the green wire that runs from the power box to the motherboard. (I put up a picture of it below) Again, great job!!
    hello bneil4434,
    i tired this but no result. when i put the joined cable on the cabinet the fan worked and when i removed it it went off then i tried to power it on it was the same orange light.
    Just doing a follow up to my comment from over 2.5years ago (you can find that comment below 2015-04-08). The fix curtisg gave worked then and still works now. Again, thanks for the Instructable!
    Please friend how will I solved the problem of my dell desktop c p u that only blink yellow Light but will not power
    while having this issue with dell laptop i did some research and i find out this can be fixed . just restart the laptop using the power key and hold for like 30 sec and let it turn on . try booting into using safe mode using the f8 for all other steps follow this post http://fixingblog.com/fix-laptop-computer-not-turn-on/ i am sure this may help
    I am having troubles turning on my computer (it is an optiplex 745 desktop) every time i turn it on the fan start and the disk drive works but on my monitor it says no signal, the desktop it self has an orange power light, now im wondering, is this OLOD?
    Hi there Aidan C,
    Ok so here's what u can do,
    #1 Method.
    Open up ur pc case
    Pul out the power cable from behind the pc
    Now pull out the cmos battery
    Now replace the cmos battery with a new one.
    If this doesn't work check ur vga cable , if any of the pins r damaged replace the entire cable.
    This should work I hope.
    And good luck.
    FIX 1:
    unplug all cords from your CPU then hold the power button for more than 60 seconds, this should clear the CMOS. then plug back the cords and you are back to work.
    FIX 2:
    JUST Clear Your Computer's CMOS to Reset BIOS Settings. 1. unplug all cables from your computer 2. remove the CMOS battery from the motherboard for over 6 minutes (to ensure the BIOS is reset) 3. plug it back in and you are good to go.
    FIX 1 worked for me!!!! My power breaker tripped and when I came back after resetting the breaker, my optiplex 755 had the amber/orange light on with the fan running. Your tip reset the computer.
    Thank you!
    My dell pc tower blinkin orange light the light is on inside as i open but it is blinking up front power button
    Hello sir i try this step but not work..plz reply me i want solution
    Orange/amber light is solid, not blinking (Computer is a Dell Dimension E520). Tried all the suggestions recommended in the posts below. No fan activity or indication computer wants to start up. Just did the dust blowout thinking that could have been cause. I am also suspicious it could have been lighting strike but not certain as I cannot pinpoint. Any guidance on any other troubleshooting tips? thanks sk
    TRIED BUT ORANGE LIGHT STILL ON. Method didn't work for me. This is the same as a reset button. Power light never did come on....Thanks, Paul
    Thank you for sharing this. You saved me a headache that you wouldn't believe! (on second thought you probably would.)
    it has an ati-102-a771(B) and ad280p-00, aswell as a GSA-H3E1N
    sorry i have no idea what these things are called because i am just getting strted with my computer
    I have dell optiplex 745..
    So its not work
    Power bottun light is orange and blinking
    omg, this is only temporary. orange means usually problems with power supply. same effect you can archieve pressing test PS button on back pane and at the same time power button. however for real heal you need to disassemble power supply and replace bad caps. see http://www.badcaps.net/forum/printthread.php?t=33442
    Worked for me, Thank you.....
    I tried above - with these results:
    Power switch would not work - so I did the work-around on this blog(OLOD orange light of death) - power on BUT :1st: orange light (Power UP Button)stays on(should be blue) -2nd: computer system not working - does not get to BOOT system even (where you select F2)? What's the problem?? This is a DELL Inspiron 530, I have had it for 4 or 5 years. All of a sudden power switch don't work - so I did the above work-around where you run a ground wire to chasis - it powered up but two symptoms as listed above.
    Clarification: I did the wiring change mentioned on your site -(OLOD orange light of death)- that is splice into the green ground wire from the power supply, touched the wire to ground on chasis - fans came up to speed - power seemed to be on - but system did not come up?? As I mentioned above - the power button stayed orange (should have turned to blue) - system did not get to BOOT file (where you can select "F2" to modify boot sector. Just ran like that - actually hung there for-ever. I messed around some more AND finally got the system to come up by hitting POWER on/off switch. I was able to power down -then- power up system - now I am afraid to POWER OFF
    AGAIN - FOR FEAR I CANNOT BRING THE SYSTEM UP AGAIN. So my question is what went wrong with the ground wire thing your site describes -(OLOD orange light of death)- . I suspect the "amber" light on the "mother board" was not lite - when the fan came on - BUT-
    system did not come up. I was wondering is there is a "reset" button I could have pushed (on the mother board or where-ever)???
