Fix the Power Switch on BObsweep Pethair or Standard
Published
Introduction: Fix the Power Switch on BObsweep Pethair or Standard
About: I am Bob and I love floors! I also love vacuuming, and sweeping, and mopping. And, I can do them all at once. I am strong, yet sensitive... and independent, yet obedient. I also have a brush and a dustbin s...
The video and instructable will guide you through the necessary steps to replacing the power switch on a bObsweep Robotic Vacuum. It includes:
  • Opening and closing bObsweep
  • Removing and re-installing the battery
  • Removing the main board and power switch
The instructions for this repair are the same on bObsweep Pethair and Standard.
Step 1: Remove the Battery Cover Plate
    Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    Lift the cover plate to expose the battery.
    Step 2: Remove the Battery
    Lift the battery up and out of its compartment. Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
    Step 3: Remove the Main Brush and Cover Screws
    Flip Bob over and remove the 7 screws that hold the cover together.
    1. Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
      Note: Depending on your model, there may be only 6 screws installed on bObsweep.
    2. There are two screw holes inside the brush compartment: one in the centre, one on the left end. Remove both and keep aside for reassembly.
    3. There are five more screws around bObsweep's edges. Two are installed at the top and bottom, and one on the right end of the main brush.
    Step 4: Remove the Cover Circuit Plugs
      Flip bOb back over so you can see the screen. Lift the cover up to reveal bObsweep’s main board.
      Detach the power inlet from the cover. Grip and slide it out.
      Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release from the motherboard.
      • On the bottom left corner: a small connector with red, black and white wires.
      • On the top edge of bOb’s motherboard: a wide multicoloured connector.
      • One thick white wire that attaches on the right side of the previous connector.
      Step 5: Remove the Main Circuit Board
      After opening bObsweep, you will see the main board in the center. To remove it, you will need to unplug 11 more circuit plugs and uninstall 3 screws.
      • There is one in the centre of the motherboard, near the multicoloured plug for Bob’s left wheel.
      • The second is close to the top right corner.
      • The third is near the bottom right edge.
      Keep all three screws. They will be needed later while installing the replacement main board.
      Step 6: Detach the Power Switch
      The power switch is on the right side of bOb’s bottom half. Slide it straight upwards to remove the switch.
      The wires of the power switch are secured inside the battery compartment. Remove the screw in the bottom left corner of the battery holder, and lift the plastic piece up.
      Pull the wire out of the compartment to detach the power switch and its wires from bObsweep.
      Step 7: Place a New Switch in BObsweep
      Slide your new switch into the open space on bOb’s side.
      Then, place the black and red wired end into the battery compartment. There is an indent at the bottom corner of the battery holder, where the wires should sit.
      When you’ve replaced everything correctly, lay the wire cover down and install the screw that secures it to bOb.
      Once the power switch repair is complete, replace the main board, battery, and cover before using bOb again.
      Step 8: Replace and Secure the Main Board
      Place the main board back in bObsweep. Make sure the holes in the main board align with the screw posts on Bob.
      Install the three screws to secure the main board.
      Step 9: Start Connecting the Circuit Plugs
      The order along the motherboard’s left edge from the top down is:
      A small yellow and black circuit plug.
      The main brush motor's circuit plug which has two pairs of twisted wires, one red and white, the other pink and black.
      A wider, multicoloured circuit plug which is attached to bObsweep’s left wheel.
      Finally, a small circuit plug with black and blue twisted wires.
      Step 10: Re-attach the Bottom Row's Circuit Plugs
      The order from left to right along the bottom ledge should be reconnected as follows:
      A small circuit plug with red, black, white, and brown wires.
      A small yellow-wired plug.
      A small black and orange-wired circuit plug
      A circuit plug with multicoloured wires and a wide base which connects to Bob's right wheel.
      There will be 3 empty spaces left in this row. Two will be filled when you put the cover back on.
      Step 11: Attach the Rest of the Circuit Plugs
      At the top of the motherboard’s right edge is a wide, red, black, and blue circuit plug. (Highlighted Pink)
      Beneath that is a smaller plug for Bob’s power inlet with orange and black wires. (Highlighted Green)
      Plug each one into the motherboard in the suitable slot.
      There are two wide, multicoloured circuit plugs that attach to the top edge of the motherboard. One was removed to detach bObsweep’s cover, so the space will stay empty for now. The other plugs in on the right side of the open space.
      When all have been connected to bObsweep, begin putting the cover back together.
      Step 12: Place the Cover on BObsweep and Secure It
      Make sure to replace the cover carefully when closing bObsweep.
      Reinstall all the screws you removed to start the repair.
      Note: Depending on your bObsweep model, there may be only one screw in the brush compartment.
      Step 13: Install the Main Brush
      Place the end attachment on the main brush. Then, line up the square peg end with the indentation inside the brush compartment and lower it in place.
      Install the screw that holds the end piece on the brush.
      Step 14: Install the Battery
        Plug the battery in and press firmly to lock in place.
        Push the wires to the left side and slide the battery down. The barcode should face up.
        Make sure the wires are tucked in and the battery lies flat. Then, place the battery cover down and install the two screws that hold it on Bob.
          • Woodworking Contest
            Woodworking Contest
          • Casting Contest
            Casting Contest
          • Microcontroller Contest
