3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fix the Red Ring of Death! (without towels!)
Step 6Drill bigger holes
Drill bigger holes
To use those 5MM machine screws, you'll need to widen the 8 screw holes in the metal case, that previously secured the X-clamp posts. They are highlighted in the second photo.
To widen them, use a 3/16 inch drill bit with a drill press or hand drill.
If you're using a hand drill, set a wooden block under each hole as you drill it, to avoid warping the case. If you're using a drill press as I did, there should be a steel pedestal with a hole for the drill bit to pass through, saving the case from serious FUBAR-age.
Have the bit spinning before you push into the center of the hole. Repeat this for all the holes. Make sure there are no burrs left on the holes or shards kicking around in the case afterwards. Bang it around a few times to get them out, the last thing you'd want is to have your 360 die from little pieces of metal shorting it out.
13 comments
Jun 11, 2010. 3:30 AMTheSereminator says:
I don't have a drill press or hand drill, but I do have a hand electric drill and plenty of different bits, would this be ok to use for widening the holes?
Jun 12, 2010. 9:42 PMHingedmosquito says:
I am sorry to disagree with this post but if you get the right supplies you do not need to drill holes at all. just do a little more research. maybe check out this site http://www.llamma.com/
Mar 12, 2011. 11:14 AMslavapalooza says:
I am sorry to disagree with you, but I read the instructions on llama's website and it also calls for drilling larger holes. Maybe you should do a little more research.
Mar 16, 2011. 4:12 PMHingedmosquito says:
Have you fixed this problem before? I fixed mine and it has been working 2 years no problems and I didn't drill any holes. I simply found the right screws and washers and that was that.
Jun 16, 2011. 11:49 PMacrazyfeet says:
since 2 years sounds like a hefty amount of time considering the quality of the original product, would you be so kind as to refer me to the site where you got your fixing tutorial from?
or, if you are inclined enough, would you be able to write your own guide?
I am seriously considering buying a RROD 360 and fixing it.
Thanks a bunch :]
Jul 24, 2011. 11:29 AMmvargas5 says:
he says the name of the website in the post right before the one you commented on, i don't understand? It is not that hard to look for the answers instead of acting hopeless!
is what was mentioned and with two clicks I got here:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
Jun 13, 2010. 3:11 PMMstocker says:
drilling a hole is a nice way to do this, i tried doing that the first time i fixed a RROD, but honestly, i would just suggest getting screws that will fit through the motherboard and are short enough to just screw in and thats it. i always put my screws on underneath the metal casing, makes it easier to take apart if you ever need to. plus ive found it unnecessary to even use metal washers. just get big enough nylon ones and youll be good to go. good post though.
Mar 29, 2010. 8:05 PMgoodcoldwater says:
Lmao, I have the same drill press, only difference is mine is coated with corrosion inhibiting oil on the metal surfaces to keep it nice and shiny. Good sheeaht! Go Harbor Freight!!!! Yea! XD
Jul 13, 2009. 4:59 PMscottrod says:
Where do I find 5 x 8mm screws? Can't find them at any local hardwared store or compter store.
Feb 21, 2010. 1:00 PMoriginaladam says:
Commonly known as #10 machine screws.
Jul 14, 2009. 7:41 PMmaxinater65 says:
scottrod: If u didn't disassemble yet dont go all the way. u may only need to do as I did in my post under maxinater65. just remove case and X-bars, clean heat sink past with finger nail or tooth pick, then bend bar to more of an angle to create more tension and reinstall. this worked fine for me. p.s. dont forget to put new heat sink paste on before re assembly?
Jan 11, 2010. 5:36 PMEpycFyre says:
Once you've drilled the holes, if you take a much larger drill bit and twist it with your hand as if drilling the holes bigger into the case, you will effectively clean out the hole of any burrs and cleaning it nice and purty.
Sep 2, 2009. 6:21 AMcrashrandall says:
A "Step Drill" bit is a very good solution for widening existing holes in sheet metal, and much more affordable than a drill press. The design of the bit keeps it centered in the hole as you drill.
Available cheap from Harbor Freight, and a bit less cheap from Home Depot / Lowe's / etc.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91616
Dec 29, 2009. 8:26 AMgeekzapoppin says:
As someone who can't afford a drill press (plus, I live in an apartment) your suggestion is a lifesaver!  Thank you!
Jan 1, 2010. 2:36 PMcdousley says:
cool i may buy som but my dad has a drill press
Jun 18, 2009. 4:14 PMcrd22 says:
The picture is a little misleading. All you need is a hand drill with the correct bit, not an industrial size drill press. Plus the piece of wood underneath is recommended.
Jan 31, 2008. 10:08 PMK.hall86 says:
putting a piece of scrap wood underneath will help on the press too because it gives the bit something to keep cutting, giving a more clean hole once drilled...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:Jake Turner(Jake Turner)
Where to start... I get bored and reach for either a soldering iron or a keyboard. I have a short attention span. I love working with electronics, eating pizza, and making all sorts of things. I've be...
more »
