Step 8Re-installing the heatsinks
Pick whichever heatsink you wanna put on first. Make sure the CPU's copper heatpipe is facing away from the GPU heatsink when you put in on. The GPU heatsink won't let the CPU heatsink on if you put it on wrong. The easiest way to get this right is to look at the smudge marks on the heatsinks, and match 'em with their processors. When you thread the screws on, start each one off lightly, then get them up tightly. Try to get them evenly tightened to avoid having too much pressure on one side of the processor, and too little on another. When it's all done right, the heatsinks should not move at all.
Now we get to test it out!
P.S. does anyone know any of the new updates for 2011, thanks!
If there is any doubt, try using a screw in an engine compartment. Also, because bolts usually have to be held in place by either a chemical compound or a nut on the other end they are made of a stronger metal that is not easily twisted in half during the torque of removing it or putting it in.
Just saying.
http://www.youtube.com/watch?v=iAL0EBK-4ps
cheers guys
I also suggest just the tiniest glob of PVA to keep the washers in place until final assembly.
Also i found site to be very helpful when testing:
http://forums.xbox-scene.com/index.php?showtopic=484726
I ended up using the information under the "Secondary Error Codes" section. It was very helpful in determining the problems when nothing was being output to the screen.
This is the thermal paste i used as well
http://www.radioshack.com/product/index.jsp?productId=2216879
Worked very well.
Best of luck to everyone!
This step will probably get your xbox running. it made mine run like new! you want to do the last 6 steps of the llamma tutorial. just count 6 boxes up from the bottom. it will explain why it works there. dont forget you want you fan NOT clipped into the metal. you cant find the tutorial here
good luck! if you have trouble just reply back.
