Fix Torn Currency
Introduction: Fix Torn Currency
Sometimes I get handed a note that is partially torn or was completely torn in half and was attempted to be put together again using cello tape, the only problem is that when you try to use these notes, shopkeepers are reluctant to accept them. The proper procedure is to return them to the bank but that can often be a hassle and not worth the note you are trying to replace, so the next best option is to repair them yourself.
The main ingredient of this insructable is white paper glue (water souble).
Other items you need are a glass work surface, a razor blade for scraping the glass and a small container for mixing the glue.
Step 1: Prepare the Glue
Depending on what glue you use, you may need to experiment with this a little. Mix about 1 drop of water with about 5 drops of glue, the glue should be about the consistency of condensed milk.
The reason for thinning it with water is so that the glue gets absorbed properly by the currency note, this also makes the glue layer thin and almost unnoticeable in normal use.
Step 2: Apply Glue
To apply the glue I took about a drop of it on my finger tip and applied it across one edge of the torn note. Remember that the glue becomes almost transparent when it dries.
Step 3: Join the Pieces
Place one half of the note with the glue still wet onto the glass surface and dab it a little bit so that the note sticks to the glass. Next place the other half of the note next to the first half half and align the torn edges so there is no gap between them.
If required apply some more glue along the tear and let it dry completely. This will leave a very thin membrane of dried glue on the note and likely to tear. So now we apply some more glue over the dried first layer, the idea is to build up the dry glue skin till it is reasonably strong enough to be handled as you would normally handle the currency.
Use the razor blade to carefully scrape the note off of the glass. Flip the note and repeat the procedure. Essentially you will be left with dried glue skin / membrane that would be holding the currency together.
Step 4: All Finished
When finished it is normally not possible to tell that the note has been stuck with glue unless observed closely. This technique may also be used to repair other paper articles such as old books, treasure maps etc
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    Brother, you have shown an Indian note in the picture. Please note that repairing torn currency notes is illegal in India.
    please... note?
    sorry, that's not helping, is it?
    Please note that I am in no way trying to pass off an unfit note as a fit one. The intention is to preserve an otherwise mutilated note so that it can be exchanged at the bank by proper procedure and you get back its full value. For reference see this link ( point #3)
