3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fix your bike. Grease your bearings and change your freewheel.
Most people don't realize this, but your bike needs maintenance. Your axle bearings needs to be cleaned and repacked with grease every 500 miles (100 on a mountain bike).
This instructable shows how to repack your axle bearings and install a new freewheel body (if you need one).
Step 1Remove the wheel from your bike.
If you don't know how to do this much already, this may be too big a job for you at this point.
49 comments
1-40 of 49next »
Feb 24, 2012. 9:41 AMpchretien says:
This is hell of a great ible! I have to change the bearings on my rear wheel and didn't know where to start! Winter with the snow and salt is terrible on the mechanic! Thanks again for sharing ...
Mar 28, 2009. 1:52 PMcoolpizzadude says:
will white lithium grease is what I used on my bike is that ok?
Dec 13, 2009. 8:23 PMmcflyalright says:
white lithium grease if fine.
Jun 23, 2011. 7:33 PMstruckbyanarrow says:
it doesn't last too long though...
Apr 29, 2011. 12:15 AMzilcho says:
I just did this to both wheels on my old bike and it really makes a difference. The marine axle grease i bought was a strange turquoise color so I hope thats ok.
Jul 11, 2008. 3:38 PMBearclaw_Michael says:
I put grease fittings on my wheels a few years ago. I found it makes a huge difference, it keeps my bike roling smooth and quiet by keeping it properly lubricated. (Cell Phone Pic in Poor Lighting) But I'm sure you get the idea.
Sep 26, 2010. 12:52 PMsharlston says:
How did you do that?
Oct 28, 2010. 7:24 AMBearclaw_Michael says:
Hi,
Sorry I didn't get back with you sooner but I have been on vacation and that included staying away from the computer.
It was really just a matter of pulling out the axle bolt, then I drilled a hole in the hub housing and threaded it with a tap for the grease fitting.
If there is a trick it's getting in between the spokes with the drill, depending on your wheel and your drill you might need to use a short drill bit or even a right angle drill made for tight spots.
Other than that it is pretty simple and it really does make a big difference.
Thanks for asking
Oct 28, 2010. 9:48 AMsharlston says:
thanks for the info,how do you get grease into their? im guessing a syringe?
Oct 29, 2010. 3:56 PMBearclaw_Michael says:
Those are zerk grease fittings like on a car, so you use a regular grease gun to pump the grease in.
Nov 12, 2009. 8:03 PMairsofter1 says:
 Can you replace a six speed cog with a seven or eight speed cog?
Oct 24, 2010. 9:33 AMsharlston says:
How do i tell between the two?
Jun 15, 2010. 2:47 PMguitarisnice says:
Great tortal you got here thanks a lot. You done great work on this one. One question: Is there a easy way to find the right casett for my bike? Need a new one but dont know how to find the right one, I guess they are not standar. There are 8 chains holders or what you call it.
Dec 13, 2009. 8:25 PMmcflyalright says:
just to note that newer bikes used sealed bearings (like skateboard wheels) so this might not make sense for your bike.
Jan 28, 2010. 5:19 AMsharlston says:
wrong theres no such thing as sealed bearings for bikes theyre either like a real bearing with rubber seals which would be shielded or there would be a cone on the thread of the hub which are standard for many bikes now
Oct 15, 2009. 12:35 AMsharlston says:
my rear wheel makes a really loud ticking noise when im pedalling and its really stiff
Oct 15, 2009. 10:45 AMsharlston says:
can it still be ridden?
Aug 29, 2009. 9:56 AMsharlston says:
could you decribe how to remove the nuts near the wheel not the forks in a bit more becuase i havent got the special tools to do it and i dont know how
Aug 30, 2009. 8:45 AMsharlston says:
i dont need to remove the caseete becuase om greasing them on my front wheel i need to take the nuts off
Sep 21, 2009. 12:09 AMsharlston says:
i managed with 2 adjustable wrenches ive got a draper bike toolkit how much do i tighten the rear gear stack thing?
Aug 31, 2009. 2:04 AMsharlston says:
no im dealing with my bmx
Sep 10, 2009. 5:12 AMchat doc says:
the only close-ups which aren't blured, or shot with a good light are at step 9. Yet, this kind of instructable could be really good, if good pics with the good content.
Sep 2, 2009. 3:19 AMsharlston says:
do you really need to do it every 100miles on a mountain bike ive had my bike for 4 years now and traveled inexess of 700 miles and never greased them once and today i eventually greased them and it turns out the old grease is still there so i filled the whole hub with grease
Sep 2, 2009. 9:59 AMsharlston says:
well i took it apart today to have a look and its just a standard cone the bikes a appolo fs.26 its a pretty cheeap bike
Jul 10, 2009. 3:21 PMjunkyjunkerson says:
Pictures 2-4....TOO FUNNY!
Feb 12, 2009. 11:03 PMpjax says:
greasy hands on the brake discs. ouch!
Feb 15, 2009. 5:06 AMpjax says:
oh yeah. rotors. the name slipped my mind yes, one should definitely clean the rotors if you get grease on it (i was hoping you'd mention that on your post.. :D constructive criticism) my take? don't get grease on it on the first place! clean your hands/avoid touching the rotors
Aug 17, 2008. 9:37 AMdouble ott says:
is there any way to improvise with the cog holder? I am taking apart my old bike, and I want the gears and I dont really care if anything gets damaged in the process. I have the freewheel tool but I dont really want to spend money on this cog holder if there is a free way out of it
Aug 17, 2008. 9:24 PMdouble ott says:
oh, so I turn to the right not the left? and how far should I stick in the freewheel tool? thanks btw
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:Marsh(People Who REALLY Build Things)
Please subscribe and rate my stuff! Your comments really motivate me to make more and better instructables.
