Fix Your Binoculars......It Is Easy!
42,746
7
9
Posted
Introduction: Fix Your Binoculars......It Is Easy!
Do you have some primates and see wrong with them?
Do you see the double image and gives you a headache?
 Well has a solution.
Step 1: Deconstructing the Prismatic
If you dismantle the prismatic can see that there is a small screw that is supported in each of the prisms.
Normally these screws are located outside the binoculars.
Not necessary to remove the prismatic, must be located where they are (the screws are very small, and sometimes are hard to find).
Si desmontamos el prismatico podemos ver que existe un pequeño tornillo que se apoya en cada uno de los prismas.
Normalmente estos tornillos se localizan en el exterior del prismatico. NO hace falta desmontar el prismatico, hay que localizar donde se encuentran (los tornillos son muy pequeños, y a veces son dificiles de encontrar).
Step 2: Cause of the Problem: NO Parallel Light Rays
We see the double image because light rays (image) that leave for us is not parallel.
Vemos la imagen doble porque  los rayos de luz (imagen) que salen de los oculares NO es paralela.
Step 3: Solving the Problem
To solve the problem we must ensure that the light rays go parallel.
For that we turn the screws (move the prisms), so get moving with the light rays.
Para solucionar el problema hay que hacer que los rayos de luz salgan paralelos.
Para ello debemos girar los tornillos (mover los prismas), con ello conseguiremos mover los rayos de luz.
Step 4: Last Tip
To work comfortably:
1 .- Put the binoculars on a tripod and attach it securely.
2 .- Focuses any point with the binoculars (really the double image)
3 .- Move the screw slowly until the two images match.
Once the work can be used (carefully) a little hot glue to prevent movement in the prisms.
If this instructable helps one person I am satisfied.
Thanks for visiting this instructable.
Para trabajar comodamente:
1.- Coloca los prismaticos sobre un tripode y sujetalos fuertemente.
2.- Enfoca cualquier punto con los prismaticos (veras la imagen doble)
3.- Mueve poco a poco los tornillos hasta que los dos imagenes coincidan.
 Una vez hecho el trabajo, se pueden usar (con cuidado) un poco de hot glue para evitar movimientos en los prismas.
Si este instructable  sirve de ayuda a una sola persona me doy por satisfecho.
Gracias por visitar este instructable.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    9 Comments
    Many thanks - I was just about to bin my binoculars, but this simple procedure has saved them. Good as new again !!
    ¿Alguien sabe de algún sitio con instrucciones para reparar el mecanismo de enfoque de los binoculares? tengo unos que se soltaron del tornillo central y tengo que mover los oculares manualmente.
    GRACIAS
    OJO con el HOT GLUE! Comúnmente deja manchas blancas indelebles alrededor de donde se aplicó. (Warning with HOT GLUE! Usually it leaves indelible white spots around where you applied it.) Welcome to the BIC ("Bilingual Instructables Club")!
    Gracias por la bienvenida. He buscado mucho un sitio parecido a este en español, pero no lo he encontrado.
    Yo lo sigo desde hace 4 años y un día, y gran parte de lo poco que he aprendido de inglés se lo debo a la interacción con esta página, que es la primera que leo luego del correo. Respecto del OJO con el HOT GLUE! mira lo que le pasó a la pobre Ángela:
    Lo de Angela es un trabajo burdo comparado con los trabajos refinadisimos que se ven en esta presentacion, ahi va el enlace: http://www.megaupload.com/?d=XM1H7SVQ
    Muy bueno, seguramente extractado de http://thereifixedit.com/, ¿no?
    If you're repairing cheap bins, this is fine, but better ones have water-tight and gas-tight seals, and often have super-dry inert gases filling them, which are lost the instant you open them up.
