For this project you will need the following:
- wire snips/strippers
- soldering iron
- solder/flux
- replacement jack
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
There you go :)
Take a look at:
http://highfields-arc.co.uk/repairs/headphones.htm
for explanation of wires, plugs etc.
If a DIYSer can use a soldering iron properly, then he/she is fully conversant with a basic volt-continuity meter.
For one, you can't go wrong with the 'common' or ground wire. After that, just connect it as rihaller says.
As a rule, one of the wires may be intermittenttly contacting or even broken at the plug but not likely both.
Smart as most DIYSs are, use the process of elimination.
Nice work! for smaller hadphones in ears and ear buds the wires are usualy coated in plastic you need to burn off as n fyi.
To save myself from future hassles, I just soldered a 3.5mm female jack inside, tons of glue gun glue. So no more worrying about broken cords or plugs. :D
My brother had similar problems with a few different pairs of headphones, but instead of replacing just the jack I replaced the whole cord, either way nice work:)
Now I have to cross my fingers that I encounter this same problem so that I can buy a real wire strippers, not that useless $0.99USD job I've got in my toolbox.
Thanks for posting this.
