3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fix your stuck Ford ignition
The key wouldn't turn in my mother-in-law's 2004 Ford Focus wagon. After doing some research, I found that apparently this is a typical problem in many Ford vehicles, especially the 2000 to 2005 Focus.
I looked around online, and found a few different solutions to the problem. One involved tapping the key with a hammer to get it to work, another involved drilling out the old cylinder to install a new one.
The biggest problem I found was that each solution was either temporary, expensive, or involved getting a new key. This means that you would end up with one key for the doors, and a different one for the ignition - not the solution I wanted.
This instructable will show you how I solved the problem. I ended up with a new ignition lock cylinder, but continue to use the original, programmed key. The total cost of the repair was the price of the part - $72.99 with tax. The whole job took me about 4 hours, but I had to figure out how a lock works without much help. If I were to do it again, it would probably only take 2 hours.
The repair involves changing the ignition lock cylinder for a new one, and reprogramming the computer to accept the new keys. Ford has a passive anti-theft system (PATS) where each key has a chip, and they have to be programmed in. No problem if you've got two functional keys, because you can add new ones, but you have to be able to turn the key in the ignition to do so.
Step 1Stuff you're gonna need
Stuff you\
Here's what you need to do the fix:
Tools:
10mm wrench
#2 Philips head screwdriver
T20 Torx screwdriver
8mm socket and driver
small screwdriver (I used a small torx screwdriver)
utility knife
putty knife
small flathead screwdriver
small paper-clip
clamp or vise
vise-grips
needle-nose pliers
clean, light-coloured work surface
Optional:
magnifying glass
ratchet
snap-ring pliers (might make the job easier, but I did it without them)
power drill and grinding bit
Materials:
replacement lock cylinder (comes with 2 chipped keys)
grease
2 comments
Feb 20, 2011. 5:21 AMbknow13 says:
The new replacement cylinder from Ford [I work at a dealer] is a kit. They "get all the money" but you can code it to your old key. A little tedious but rather simple. The instructions require the key code, getting it is worse than pulling teeth, but if you don't destroy the old cylinder taking it out the plungers are numbered. So you could just copy it. It needs to be done before the cylinder is totally stuck or you will destroy it trying to take it apart.
There's a special tool to fit the cap but all it does is peen over the edges nice and neatly. If you take care on a clean surface you can do a nice job with the end of a screwdriver.
I haven't checked [hey, I sell the Ford stuff!] but I bet there's a more reasonably priced aftermarket option.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jptrsn(Open Teaching Resources)
Teacher in Quebec, Canada. I am devoted to learning - teaching just sort of follows...
