Step 7Adhesive application
Don't think you can do this job with some 5-minute epoxy. Use a product that is intended for auto body repairs. The adhesive is temperature-sensitive. You need to work in an area where the temperature is between 60 and 85 F. If it's too cold, the adhesive won't set properly; too much heat hardens it before you can get all the clamps set properly. To attach the door skin, apply a 1/4-in. bead of adhesive from the applicator onto every surface of the frame that will come in contact with the skin. Apply several large dollops of adhesive to the side-impact beam so the middle of the skin will fasten to it firmly.
Add Comment
