3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fixing Major Dents
Step 9Finishing Up
Finishing Up
Now the door is ready for primer and paint. Don't forget to paint the inside of the skin first to prevent corrosion. Follow the paint manufacturer's recommendations as to how many coats are needed and drying times. Keep any drainholes along the door's bottom edge clear of adhesive and paint; if they are blocked, water will collect inside. Then you and your helper can reinstall the door on the car, making sure to align the hinges with the marks you made on the body. You may have to make slight adjustments to get the door gaps right, since the new skin might fit slightly differently. Once the door is back on the car, reinstall all the pieces you removed. Crimp the flange by using a body hammer to carefully tap the excess metal over and up tight against the frame.
2 comments
Nov 18, 2010. 1:40 PMneffk says:
This really is a lot of work. Very professional results, thought.
I have rust on the edges of my car's doors. I'm considering grinding off the folded portion and welding on a new strip of sheet metal, which I will fold into place. The result will be ugly, but the door will still shut properly.
Oct 29, 2010. 2:08 AMrprough says:
Way too much work. A used door would be far easier and probably cheaper.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
116
Author:Popular Mechanics
The official instructable for Popular Mechanics magazine, reporting on the DIY world since 1902.
