Fixing a Car Battery Pole Clamp.
1,307
10
Posted in WorkshopCars
Introduction: Fixing a Car Battery Pole Clamp.
About: As of April 2017 I have decided to no longer post on instructables. The fact that several of my published works have been removed without my consent is inexcusable. Also the insult of an author having no co...
My Wife's car battery positive pole is so slack it comes off by hand. As a result the voltage from the car's power system is pitifully low and this is causing the battery to sulfate.
Here is how I fixed this crap.
Step 1: Cleaning!
Using a brass wire brush I cleaned the pole and clamp.
Step 2: The Filler!
Using a flattened piece of copper tubing, I soldered a portion of it. I also applied solder to the inside of the battery clamp.
Step 3: Installing the Filler.
I cut the soldered section with a little extra length. I made a clip of it and had the soldered side facing the inside of the battery clamp.
I soldered both clip and clamp. Next I hammered the clip into a round shape using a 1/2inch extension as a mould.
Step 4: Completion!
Now the clamp is firm and tight onto the pole. No more free movement here.
I started the car and the voltage was consistent whereas before it was 13.0v and lower. Too bad I effed up my finger!
I hope this instructable has been helpful!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
