3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fixing a Direct Drive Washing Machine
Step 7Removing the motor
Removing the motor
Now remove the two bolts holding the motor brackets on and pop them out of the way. Unplug the motor and remove it from the machine. Your efforts will be awarded with the sight of the holy grail- the failed motor coupling. Try not to hyperventilate as you take in the view.
The coupling is in three parts: a rubber shock absorbing disk and two white gears with three prongs each. One of the gears is on the shaft of the motor, the other on the transmission. The rubber disk lives in between like the soft filling of an oreo cookie.
3 comments
Jan 13, 2009. 9:04 AMwmc says:
I have the coupling replaced and motor back on with top bracket attached. I can't get the bottom bracket to snap in place - any suggestions?
Jan 1, 2009. 2:15 PMHALABOUTIT says:
Mark any single wires outside of wiring harness. I had three separate wires attached to other gizmos and experience taught me to record what goes where when putting the wires back on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jdean2000
