Introduction: Fix/Mod a Propel Spyder Drone
Picture of Fix/Mod a Propel Spyder Drone
My nephew's dog ate his Propel Spyder drone and I rescued it from the trash hoping the electronics still worked.
Step 1: Removing the Screws
Picture of Removing the Screws
I started by removing the screws from the underside of the drone to reveal the electronics.
BAM! all looks good. I charged up the battery and tested the motors and it was ON!
Step 2: Inspecting the Parts
Picture of Inspecting the Parts
Carefully inspect the hardware and take lots of pictures so you can remember were everything goes.
Step 3: Desoldering
Picture of Desoldering
Desolder motors one at a time. Doing this Makes it easier to keep track. I took some jumper cables I had lying around and cut them to the length I needed. Then I stripped, twisted and tinned the ends.
Step 4: Extending the Wires of the Motors
Picture of Extending the Wires of the Motors
After tinning the wire that are cut to the desired length, proceed to solder to the ends of the wires attache to the motors carefully keeping track positive and negative.
Now take some heat shrink tube and apply some to one wire and a bigger one to seal them both.
Step 5: Put Together
Picture of Put Together
Carefully start to put the pieces together.
I used the top of my frame to hold the battery and basically using the frame upside down for my needs and it works fine. I'm using a hubsan x4 gen2 frame.
Add some double sided sticky tape to the bottom of the flight controller and place on you frame.
The motors need to firmly be pushed thru the sockets carefully.
Step 6: Installing the Props
Picture of Installing the Props
I didn't know where the blade needed to go so I powered on the craft and figured out what direction the motors spun and put the blade on there proper motors. I added a diagram to show the direction of how the props should be placed.
Step 7: Test Flight
Picture of Test Flight
Now its time to go for a test flight. Sync your drone to the remote and take it for a spin.
My drone fly's but is very unstable. I need to do some more modding to the frame to make lighter and balanced.
For the most it is still fun to fly.
Not bad for trash.
mpeer1 (author)2016-03-18
I've been thinking about making a new frame for my Parrot Bebop drone. I wrecked it due to really strong wind 2 days after I got it and have been using super glue, every time it lambs hard since then. Any suggestions on materials for the frame? Preferably using some in home items.
mpeer1 (author)mpeer12016-03-18
The red line are all of the fracture points. The whole arm comes off if nothing is hooked up.
idealab (author)mpeer12016-03-24
I was looking in to your situation and I don't have an easy solution for what kind of house hold stuff that could be used to fix.
What have you tried so far?
Some gorilla tape might help in those cracked areas.
I did find parts online if that helps.
Orion3399 (author)idealab2016-08-09
I want to add a camera and transmitter to the spyder but need better motors and bigger battery. I found the hubsan has 8.5mm motors but i dont own one to verify that info.
I have a propel spyder and was curious if the hubsan motors were the same size? I am looking at upgraded motors and not sure what size or how to measure the spyder motors.
About This Instructable
2,948views
8favorites
License:
Bio: We're a makerspace at the Denver Public Library! We specialize in digital media creation (music, video, games) but are pushing out to do more ... More »
More by idealab:SpheroMini MazeFidget Spinner NecklaceDIY Male to Female Jumper Wire
Add instructable to:
