Fixing That Jet Lighter You Love
Introduction: Fixing That Jet Lighter You Love
So I was fixing my jet lighter (by now a fairly archaic design but a very good one and it only cost me£1 at a car boot sale) I used to fix antique lighters with my dad, thankfully jet lighters tend to be a bit more standard for repairs.
So In this I'll cover diagnosis, repair and also dismantling and assembly (most lighters designs' are a common principle... )
Ok so i got a slightly better camera than my phone, it's an ancient canon powershot A60, only 2MP but check out the macro in the pics, it was top of the range once upon a time and it shows.
Step 1: So What You'll Need for This
- a small philips head screwdriver (the tiny ones) it almost alway philips head.
-a penknife or a small flathead screwdriver (for adjustments)
-a pair of pliers, needle nose are great her but I can do it with my fake leatherman start to finish (make damn sure the pliers aren't magnetized it's annoying)
-a safety pin or some thin tough wire or a drawing pin (you'll see what I mean if it comes up)
-some sturdy wire about 24awg (anything that fits will do (again you'll understand pretty quick) is handy
-lighter gas, really helps diagnosis, in fact try the first...
-You may need rubber tubing or a piezo spark depending how you broke it (if you dropped I already know whats wrong. the lighter in this is my drinking lighter because it's made of metal and I know how to fix it)
Step 2: Ok Diagnosis Time Doctor
First put gas in the lighter, you should have done this already but this helps us determine alot.
Fill it with gas and listen, it may leak for a up to 30 seconds but that's ok as long as it stops.
Push down the button, is there gas coming out and is there a definite click from the spark (if yes to both this will be easy)
If there's no gas coming out at the nozzle but it's going somewhere then the connection has been broken probably nothing more than the flexible gas line has slipped off the seat of the reservoir end (there's more room here so it fall off that end but it's easy to fix anyway)
If you push the button all the way down and no click go to the shop and buy a really crappy cheap electric lighter, not a bic though, their piezios have no wire.
try turning down the gas a bit (sometimes the gas can't ignite because it going too fast for the tiny arc to heat... This always happens if you set the lighter when it's hot because it starts easier but wont once it's cooled down again.
All of these things are curable, this lighter hasn't many original parts, at one point I was going to hotrod a second nozzle in but There's no room, eventually I'll make an instructable about how to make your own jet lighter.
Step 3: Opening Your Lighter Up
This step just tells you how to take it all apart.
First look on the bottom, there should be a small (mostly likely philips head) screw not far from the filler valve, unscrew it, usually that is the only thing holding a lighter together, now pull the casing down off the rest (hold on to the cap and carefully pull the casing off) now you should see the guts of your lighter, there's probably 2 pins holding the assembly together. Enter the safety pin, Use the pin or wire to push the pin out of its hole.
now try moving everything apart, careful not to lose anything (yes my pins are made from steel wire but shh the screw came off a tiny circuit board, i didn't lose it, the screw was too long to start with.)
Check the image, the parts should be recognizable, and the note will explain all...
Step 4: Adjusting the Spark
This is easily the most common problem with jet lighters because they have metal bodies...
Basically the piezo is grounding out to the body or the chassis...
All we need to do is move the wire out and put it against the nozzle so it's touching it, that'll be guaranteeing near 100% performance in lighting. The first picture here shows the spark wire end pulled out and away a bit to so we get a clear idea of where we can put it. Wrapping it around the nozzle is good if there are no close metal body parts but the best is definitely doing it like picture 2. You should have kept all the pins, but really you should hav just left it together had this been the case. Before putting the case on, see if the lighter fires up if so slide the case on again and see if it still goes, if yes screw it back on and go light something up with it (In my case a Marlboro Red but in yours it may be a fuse... )
Step 5: So I Did That, But I'm Not Getting Anywhere
Simply check where gas is going by pushing down on the lever for the gas valve on the reservoir, look carefully along the gas line, you should see something similar to 'heat wiggles' (from the change in desity between gas and air) if theres a leak, I you have a crappy BBQ lighter kicking around then cannibalize that for some gas line (there's enough for five or six replacements) and if you needed it they're a great source of igniters due to the extra long cable.
If the gas still isn't getting out the nozzle then the nozzle's clogged, symptoms include the lighter bursting into flame for a second during use. take some thin wire or a pin and put it through the nozzle to clear it.
At this point I can't think of much else to go wrong, if the gas filler valve leaks when you fill it up then tighten it. If everything works but the lighter won't light or can't hold a flame turn down the gas flow a bit. If the flame sputters and has trouble keeping going then it's too weak to stay above the nozzle, turn the gas flow up a little. Finally we put it back together.
If there's any problem I have missed comment me and I'll add steps, to be honest I can't think of anything other than components going wrong after this.
Step 6: Putting It Back Together
Right now we rebuild the lighter
From the picture you should be able to tell your own parts easily enough.
This list goes bottom to top in stacking up the components again, refer to the pictures to make full sense
- Reservoir
-gas valve lever (best put in before piezo for convenience
-button cover/s
-lid top assembly (make sure the gas tubes go back in the right place)
-slide the cover back on and screw on
Step 7: I Do Believe We're Done
Again if there's anything I missed or any questions comment me and I'll do my best to help.
3 People Made This Project!
  • Science of Cooking
    Science of Cooking
  • Pro Tips Challenge
    Pro Tips Challenge
  • Pocket-Sized Contest
Accidentally broke the gas valve lever on my xikar elx.. cracked the tank while doing so, do you know of any possible donors or fixes?
there is a pin hole in the butane chamber.. what should i do?
Where can I buy a rubber hose for the fuel line w/out having to buy it online? I've already tried getting one from another lighter but none have one that's long enough.
i really want to build a jet lighter from scratch.........
are there any lighters made from much higher quality parts? they all seem to be asasembled from the same junk.
i thought for sure id find someone who builds super high end hand made lighters of any type but no luck.
I've got a vintage Colibri that will spark/light, but won't hold butane. On closer inspection, there are some cracks in the plastic butane resevoir (see pic). Does anyone have any suggestions for plugging these holes? TIA
they sell a plastic weld at the home depot.
I recently purchased two Single Torch lighters. It seems there is a piece in the torch on these lighters that fall out easily. I was able to keep one together for the most part but the piece keeps falling out. What is the name of this piece? Is there somewhere I can purchase a piece like this without buying a whole new lighter? Is there a way I can get it to stay in the lighter?
Well I believe I figured out the name of the piece I am missing. I just need to know how to get it to stay in and where to buy it, if I can without purchasing another lighter.
that piece screws in. please let me know the name of that part.
I have the same problem with a colibri vortex lighter. whats the name of that part.
