Fixture-Free Design Tips (tabbing)
Published
Introduction: Fixture-Free Design Tips (tabbing)
About: Designer and engineer from California! Interesting in rapid prototyping, robotics, automotive, UX/UI, HMI, music, and consumer product design.
Get tips on how to design stronger, better, more intricate interlocking assemblies.
(Click each image for additional information & attribution).
Step 1: Why?
Having the ability to rapidly create tabbed acrylic assemblies has proved really helpful for me in a variety of cases! I've been able to rapidly design and create robots, rovers, sculptures, chairs, a dress, and a variety of other artifacts - all without using a screw. You can use acrylic assemblies through all parts of a product development process, from early conceptualization and form ideation all the way through to final product.
The rendered acrylic structure is inside the dress - it's custom fitted to the model.
Step 2: Measuring Kerf
When designing any laser cut part or assembly, it's important to consider kerf.
Non-zero kerf thicknesses (the reality of laser cutting) mean that holes have a larger diameter and edges are further inside than you've designed in CAD or Illustrator. Kerf charts exist! Many manufacturers will provide kerf values for the materials they create. However, kerf can vary from cutter to cutter and material batch to material batch; it depends on real material thicknesses, how defocused the laser is, and how precise the laser beam is. The best thing to do is test a small sample of the material yourself (using something simple like a 1" x 1" square) and measure it. Take several measurements and average them to get a very good, local, immediate approximation of the kerf.
Step 3: Designing Around Kerf
Now that you know the kerf on your material, you need to know how to design around it! I like to design all of my parts as if kerf doesn't exist. This assumption lets me design any interlocking or tabbing section parametrically since I can make tab holes the same size as the tab itself. As you never know when or how many times your design or material might change, it's really advantageous to design as parametrically as possible.
This might mean making tab hole widths equal to the width of other parts or assuming a hole is the perfect size to correctly press fit a dowel.Right before laser cutting, expand the outer surfaces of each part in the CAD software (Inflate in Maya & Rhino, Offset in SolidWorks) by the kerf value that you measured earlier. The diagram below illustrates how this might look.
If you're using a compressible material (like wood, hardboard, or cardboard), the average of the kerf values you measured should work well. If you're using something more rigid or likely to crack (like acrylic) and having pieces interlock or tab into one another, it might be beneficial to increase the outer surface by a value a little less than kerf.
This means your parts in the real world may end up a little smaller than in your design. This can be good! If you overestimated kerf, some of the widths or heights of your parts may have ended up too large (or the holes may have been too small). Even if you didn't overestimate kerf, the variability in the laser cutter could still cause these errors. If the assembly ends up having any interaction between two pieces that is too tight, the materials can crack.
Step 4: Laying Out Parts
Be thoughtful about how you use material! Pieces break. Designs change. Laser cutters fail. Just because you don't think you need more material now doesn't mean you won't later. Save money. Save time. Help the environment. Help others (or yourself).
Also, be sure to consider kerf when you lay out parts. If, for example, you were to cut a set of pieces that are meant to interlock, you might lay them out in the orientation of the bottom (with red lines).
You feel proud of how efficiently you've laid out your parts. You're pleased with how little material you're wasting. However, when you cut your pieces out, they're all substantially smaller than expected. This is because you didn't consider kerf in your layout, so all of your parts are smaller than expected and several are even smaller than if you had cut them individually as their edges were hit twice by the laser.
Step 5: Tab Order (AKA Consider Assembly)
Be sure to think about the assembly process! Very generally speaking, it's best to try to have some pieces be all tab and some pieces be all tab-hole. However, with intricate structures that have several hidden layers (such as the box with lips below, which contains a servo, circuitry, a microcontroller, 3D printed parts, and part of a printed lip structure), the process can get a bit more complicated.
Remember that you may need room for you to reach inside and apply adhesive or tighten a screw. For more information, check out any textbook or article about design for assembly.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
