3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fizzy Cranberries
Fizzy Cranberries
These lovely (and tasty) bottled cranberries have been a favorite in my home for years. They started as a practical way to store cranberries year round, and we were surprised to find that over time they become slightly carbonated adding a delightful fizz to muffins, pancakes, berry crumbles and other breads and desserts.
You will need:
*Fresh cranberries (available from any grocery store around Christmas time)
*Pint-sized jars made for canning
*Lids and bands
*Water
*White sugar
*Large cooking pot
*Home canning pot with lid and inner rack
Step 1Prepare the cranberries and jars
Put the cranberries in a collander and remove any squished, shriveled, or otherwise undersirable cranberries.
Wash the jars and rings in a dishwasher. It is very important that the jars are sanitized or the fruit may become contaminated.
11 comments
Aug 14, 2011. 11:14 AMwinterwindarts says:
A couple of things: first, you shouldn't leave as much headspace (air) as is shown in the photos. Too much headspace is just as bad as too little. Cranberries do have air pockets inside of them-if the excess space is due to those bursting during the canning process, leave a little less before sealing the jars. I've never come across an "official" recipe for canned cranberries so I'm not certain what is required as it varies depending on what you are making...but what is shown is definitely too much. The recommendation of having the liquid to the bottom of the threads is a good generalization...but that is what you *probably* should be aiming for after the air inside the cranberries is added to the initial headspace.
Second, the "fizziness" is unlikely to be due to fermentation as the seals don't break (if it was actual fermentation the CO2 produced would most likely break the seal). The "fizziness" is a phenomenon I have noticed while mixing high acid fruit juices-often it occurs within minutes. As cranberries are very high acid this is something that I would expect would happen with them. It's an effect of the acid rather than fermentation even though it seems similar. If anything it's proof that the canned cranberries are SAFER than other canned food. The increased "fizziness" over time would be expected as the structure of the cranberries slowly broke down from the acid, allowing more juice and therefore even more acid to be released..
As a final note-and I'm glad to see that the author does do this-canned food should never be stored with the rings on. This is a detail that a lot of people keep forgetting. If the band is kept on it can cause problems with the rubber seal, making it stick on to the jar (possibly even with the button still down) even after the seal has failed, making it seem "safe". Botulism doesn't produce tell tale gas so it can grow with a failed seal even when the button remains down. Without the bands, if the seal fails, the lid becomes loose. Also, if a button pops up but stays down when you push it-it's still a bad/failed seal.
Aug 8, 2011. 7:03 AMBlainer says:
That sounds rather dangerous, Yazzeldorf. If yeast are surviving you canning process to produce fermentation, then you may have bacteria that survive as well to cause food poisoning. If I were you, I would carefully check the temperatures you are using and the processing time and methods needed for your fruit. The information is available in a lot of places on the 'net. Also, I have read that the skins of the cranberries need to be broken or they will not be properly preserved, because the skins are so tough. Sorry to be a downer on this, but I wouldn't want anyone to get sick.
Aug 8, 2011. 1:57 PMNoFiller says:
I have to agree that this sounds pretty sketchy. Tasty... but sketchy.
Yazzrldorf, you say that you store them without the screw bands, do the lids pop open or does the vacuum hold?
Aug 9, 2011. 10:09 AMNoFiller says:
That is really interesting. If there was fermentation going on I would not expect the vacuum to hold, any noticeable generation of carbon dioxide (fizzy bubbles) would pop the lid right off. I'm going to try this.
Aug 9, 2011. 5:21 AMkill-a-watt says:
If the end result is acid enough then botulism cannot grow. That's the only real serious danger that I see here. You can taste food from a botulism infected jar, spit the food out and still die.
Aug 6, 2011. 7:07 PMkarossii says:
The fizz is natural fermentation - the same thing that makes beer fizz...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:yazzeldorf
