Fizzy Mango Black Tea- Just Like Starbucks!
Introduction: Starbuck's Fizzy Mango Tea
Keep in mind the refrigerating Tim is 8 hours therefore you should make it before going to bed and put it in your fridge then finish it when you wake up.
Step 1: Gathering Ingredients & Tools
-Earl grey tea (I got mine at house of tea)
-David's Tea "mango madness"
-David's tea rock sugar (or any other brand)
-measuring spoons
- Soda Stream/ drink carbonator
-Soda Stream/ your drink carbonator compatible bottle
Step 2: Boil Water
Fill kettle in your sink up to the 1 litre line. Plug it in to your nearest outlet and turn it on. Wait for it to slightly boil. Do not wait until the kettle designated it is done, wait until steam is coming out and small bubbles emerge. Different kettles have different speeds, for my kettle it took about 3 minutes.
Step 3: Steep Tea
This is where your tea leaves and rock sugar comes in. Put 3 teaspoons of mango madness, 1.5 teaspoon of earl grey and 1 teaspoon or 4 large rocks of sugar. Pour all of the boiling water In and set your timer for 4 minutes. When the timer goes off take out the defuse and put your leaves in the compost. The sugar should be melted in and your tea should be a orangey Scarlett. Refrigerate for 8 hours or put in the freezer for 2 hours.
Step 4: Fizz
Pour the cold tea into a Soda Stream compatible bottle, for the source pull out the lever and twist it in, for the play pull out the lever, put it on and push it back until you hear a snap. Carbonate for about 12 seconds. Don't worry if you hear strange sounds it is not breaking and nothing is wrong the sounds are just part of the process. Take it out of the machine and put your hand over the hole then place it in the sink with your hand remaining over the hole. Slowly take off your hand after about 10 seconds for about 2 seconds and put your hand back on, continue to do this until the foam is all gone.
Step 5: (optional) Add in Lemonade
Add in 3/4 of a cup of lemonade to your drink. Do not fizz it again after (or else a chemical reaction is created and well the drink is everywhere). Shake the drink up and down about 4 times and wait until you can't hear much fizz anymore before opening.
Step 6: Enjoy!
Pour into your favourite glass and relax! Hopefully you enjoyed this instruct able and will make you own little changes to fit your taste buds! Thanks for viewing and please comment below for any suggestions, constructive criticism or positive feedback!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    @ironsmiter there are no chemicals in the tea but in soda stream flavourers there are a lot, therefore there is no chemical reaction with the tea
    Keeping the nozzle clean is the reason that you're supposed to carbonate water only.
    I plan on, eventually, modifying my spare sodastream by replacing the plastic injector nozzle with a stainless steel nozzle that can unscrew.
    Until then, I tried with a half full bottle(no liquid touching the nozzle), and it carbonated just fine. the only down side is, a half full bottle goes flat quicker than a full bottle, so make and drink immediately rather than storing in the fridge for a day or two.
    Scratch that, lol! Completely wrong!
    when you do your initial carbonation, is the tea level BELOW the CO2 straw?
    How fizzy does it get, compared to the normal carbonated water?
    I ask because my machines both SPECIFICALLY and EXPLICITLY state to NOT carbonate anything other than plain water... and since I haven't found a good way to modify the straw to be removable yet, I currently follow the directions. With a detachable (and therefore washable) carbonator straw, it would be a whole different ball game.
    Because MOST of the mixes use artificial sweeteners that I cannot have, my current go-to recipe is either the red apple, or a home made ginger simple syrup. Has to sit longer for all the real sugar to dissolve after adding to the carbonated water, but the results are worth the hassle for me.
    This looks tasty! :)
