Flame Polishing acrylic by steveastrouk
As part of a new Instructable, I realised I would need to use a technique I haven't seen documented here before, and that is the flame polishing of thermo-plastics.
Its not hard to do, but requires access to some fairly special tools, ideally an oxy-propane or oxy-acetylene torch.Here, I am using a "Jewellers" scale torch which seems to be fine for my size of work.
Polishing works by locally melting (NOT burning) the surface, and the low viscosity of the melt and surface tension in the liquid plastic does the rest.
Step 1: Preparation.
You can see here how "frosty" the curved edge of my workpiece looks, after being routed out. Preparation began with a light sanding to remove the more egregrious saw and router marks.
Next, I take a "naked" Stanley knife blade, and use it as a scraper, to plane off the protruberances.
veryken says: Aug 6, 2012. 11:28 AM
Nice edge. FYI, I polish my acrylic with a regular hand-held propane torch. MAPP gas cylinder gets a hotter flame, but not necessary. By the way, it's good idea to torch away from open cans of liquid flammables and workbench rags.
steveastrouk (author) says: Aug 6, 2012. 11:35 AM
There aren't any flammables around. That's a ceramic paper.
iceng says: Aug 4, 2012. 10:11 PM
Beautiful table edge.
Our local plastic shop uses a Hydrogen flame.
I use a hot air acrylic welder at low setting.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
