Introduction: Fire Detection Using Arduino and Flame Sensor
Picture of Fire  Detection  Using Arduino and Flame Sensor
Flame sensor is interfaced to arduino to detect Flame. Led and buzzer are interfaced to arduino to indicate the flame.
Hard ware components required:-
1) Flame sensor (Analogue Output)
2)Arduino
3)Bread board
4)LED
5)Buzzer
6)Connecting wires
Step 1: Hard Ware Connections
Picture of Hard Ware Connections
Flame sensor interfacing to Arduino
Flame sensor to Arduino
vcc -> vcc
gnd -> gnd
A0 -> A0
Led interfacing to Arduino
LED +ve is connected to 9th pin of Arduino
LED -ve is connected to gnd pin of arduino
For detailded description regarding led interfacing refer the below link
https://www.instructables.com/id/LED-blinking-using-Arduino/
Buzzer interfacing to Arduino
Buzzer +ve is connected to 12th pin of Arduino
Buzzer -ve is connected to GND pin of Arduino
Step 2: Programming
Picture of Programming
#include<SoftwareSerial.h>
int sensorPin = A0; // select the input pin for the LDR
int sensorValue = 0; // variable to store the value coming from the sensor
int led = 9; // Output pin for LED
int buzzer = 12; // Output pin for Buzzer
void setup() {
// declare the ledPin and buzzer as an OUTPUT:
pinMode(led, OUTPUT);
pinMode(buzzer,OUTPUT);
Serial.begin(9600);
void loop()
Serial.println("Welcome to TechPonder Flame Sensor Tutorial");
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
if (sensorValue < 100)
Serial.println("Fire Detected");
Serial.println("LED on");
digitalWrite(led,HIGH);
digitalWrite(buzzer,HIGH);
delay(1000);
digitalWrite(led,LOW);
digitalWrite(buzzer,LOW);
delay(sensorValue);
Copy and paste the above code in Arduino ide and upload to Arduino UNO.
Thanks,
TechPonder.
Step 3: Results
Picture of Results
Results are displayed on the serial window.
When there is Flame the LED and Buzzer automatically ON and when there is no flame amount Arduino automatically turns off LED and Buzzer.
Here based on our room condition the threshold value we took was 100 for the Flame sensor.
When we place a Flame Near Flame Sensor Arduino automatically turns on the LED and Buzzer. When we remove Flame from the flame sensor Arduino automatically Turns Off LED and buzeer.
Thanks,
TechPonder.
ahamed0081 (author)2017-08-10
Hi,
I'm trying to make a prototype which can detect fire using flame sensor and send an sms to a allocated mobile number.
Experts on coding please advice me to make the programme
arduinomaster (author)2017-05-05
//you need to include this to make a piezo run that does not buzz by itself.
// the 100 means the Arduino reads the value between 0 and 1024 or 5 to 0 volt.
// if (sensorValue < 100) if sensor reads less then 100 then do {tone(12,300,500); delay(600);}
// 12=pin 300 sound note ,600 minus (500 sound time) makes a delay of 100 milliseconds.
int piezoPin =12;
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
if (sensorValue < 100){
tone(12,300,500);
delay(1000);
else if (piezoPin = LOW);
//this sketch compiles
VaibhavB50 (author)2017-04-29
Buzzer is not working when connected in 12th pin and gnd....
andrer119 (author)2017-03-11
Hi, What is "100"... Celsius or Fahrenheit? and why does it go down? what is the measurement unit?
F16d made it! (author)2017-02-04
I had a good time learning with this my first Arduino project. I'm hoping to intergrate this into a machine tool and open the E-stop circuit in the event of a flash fire. Hopefully as an added level of protection.
alihashmi385 (author)2016-12-15
Why threshold is kept 100. What if it is kept to 200 and so?
MuhammadF231 (author)2016-10-20
Good Post....
FebrianS1 (author)2016-08-23
How to adjust the distance of fire detection range?
sai harshathm (author)2016-07-15
how much ohm resitor is used in fire alarm project
Mer (author)sai harshathm2016-08-01
I used a 330 ohm and it worked fine.
kode1303 (author)2015-08-18
Maybe this could be used to control a diy pellet burner. Hmmm ...
About This Instructable
37,671views
51favorites
License:
More by TechPonder:how to interface LCD (16X2) to arduinoHow to Interface Ultrasonic Sensor (HCSR04) to arduino unoFire  detection  using Arduino and flame sensor
Add instructable to:
