Flamenco Shoes Bag
Introduction: Flamenco Shoes Bag
Leather Contest 2017
Runner Up in the
This is a really simple bag for shoes. Like a box, just made of leather.)
Step 1: Materials and Tools
You need the following materials:
  1. A piece of good leather
  2. Zipper
  3. Cloth for lining
  4. Zipper end
  5. Threads
The list of tools isn't big too:
  1. A really sharp knife
  2. Ruler and pencil
  3. Sewing machine (I'm using a manual sewing machine)
  4. Lighter
  5. Scissors
  6. Rubber mallet
  7. Glue
  8. Screwdriver
  9. Dividers
Step 2: Prepare the Leather
Cut a piece of leather of the size that you need and mark all parts of the bag on it. I needed 46cmX54cm.
Don't forget an additional 1 cm on each side (the resulting size of the leather piece was 48cmX56cm).
Step 3: Skive the Edges
Skive all four sides, this is what you have the additional 1cm on each edge for. It allows to glue and sew them easier.
Step 4: Glue the Edges
Glue the edges as shown in the picture. A rubber mallet can be handy (it will be much faster).
Note that you need to glue only the two edges that will be on the top of your bag.
Step 5: Glue the Edges Together
Glue the other two edges with each other on the grain side (like in the pictures) and use the mallet again.
Step 6: Sew the Base of the Bag
Sew the edges from the previous step by the 1cm line.
Step 7: Lock the Thread Ends
Make the double knot and burn the thread ends with a lighter.
Cut the angles with a sharp knife or scissors.
Step 8: Prepare the Bottom Angle of the Bag
Divide the previously glued edges.
Now, glue them again but not together. Each edge should be glued to the corresponding side.
Use the rubber mallet for gluing.
Step 9: Sew the Angles and Glue Them
The lines for sewing are the left and right lines of the future bottom of the bag. Glue the angles to the bottom of the bag to make it stronger.
Note that you need to tie/burn the thread ends.
Step 10: Make Corners Stronger
For a good shape, you can beat each corner off with the rubber mallet.
Be very careful to remove excess corners...
Step 11: Prepare the Cloth
Cut a piece of cloth of the same size as the leather piece in the step "Prepare the Leather" and mark all sides of the bag on it.
Step 12: Glue the Lining
Glue the cloth as you glued the leather in steps 4 and 5.
Step 13: Sew the Lining
Sew the lining for the bag like you did in the previous steps, just using the cloth instead of leather. And we don't need to glue the bottom angles. It's better to remove them and burn the edges with a lighter.
Step 14: Glue the Zipper and the Lining
Glue the zipper first, check it (you may need to redo it several times for the best result), and only then glue the lining.
Note that gluing the cloth several times is not good because the cloth is many times thinner than the leather and glue can show through on the front.
Step 15: Sew the Entrance of the Box
I'm using a special tool for marking a line near the edge of the leather, which could be replaced by dividers.
After marking the line, just sew by it and tie/burn the thread ends.
Step 16: Resize the Zipper
Cut the excess part of the zipper, burn the cut edge with a lighter and install the zipper end (you will need a screwdriver for this).
Step 17: Beat Off the Corners Again
Just do it )))
Step 18: Polish It
The bag is already complete... This step is for making it waterproof.
I'm using KIWI, and you can use any wax you like.
Enjoy the good things and craft!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    Well done!
    Lots of work, lots of instruction.
    Very nicely done. I would recommend not to use the lining, but only finish the inside part of the zipper with a ribbon. The look of the leather from the inside is superb and linning is only needed for the protection of the leather in this case. Great work!
    Thanks a lot. I've used lining for shoes protection and lining could be cleaned more easer than leather)
    what brand of machine are you using?
    It's really old russian machine from PMZ (Podolsk Mechanical Factory)
    Ivan, I think we need a Flamenco video to go with this lovely Instructable ;)
    Well done, and voted.
    Really thanks))
    I'll ask about video, it's great idea!
