WARNING!: This pumpkin is extremely dangerous and you definitely should not make one of these. The instructions were posted here are for entertainment purposes only. I do not condone the manufacture or use of flamethrowing jack-o'-lanterns. Seriously, nothing good will come of making one of these. Don't do it.
Remove these ads by
Signing UpStep 1Go get stuff
For carving the jack-o'-lantern, you will need:
- A large pumpkin (mine was probably about 18" in diameter)
- An assortment of cutting knives. Serrated seemed to work the best.
- A marker
- Paper and pencil
- Scissors
- A spoon
- Other scraping implements. I found a chisel worked very well.
For the remote controlled flamethrower:
- Door lock actuator
- SquidBee transmitter and receiver. I had these lying around from a previous project. Any Arduino/Xbee combination should do.
- An extra ATMEGA168 or ATMEGA28 (only if using the Squidbee setup above as the receiver has no chip)
- Small can of WD-40
- 12" x 12" x 1/8" sheet of black acrylic
- SPST 5V relay
- Perfboard
- 5" x 2.5" x 2" project box.
- SPST momentary pushbutton switch
- 10K resistor
- (x2) 9V battery snap
- (x2) M-type plug adapters
- Misc. long zip ties
- 16" x 2" x 1/4" aluminum extrusion
- 3-1/2" x 1/4 bolts
- (x6) 1/4 nuts
- Tea light
- Matches
Dude who is passing by: pit pat pit pat, walks up stairs to knocks on door*
Flame throwing Pumpkin: Starts breathing fire out*
Dude: AHHHHHH, jumps back and falls of patio*
Flame throwing pumpkin: MWHAHAHAHAHA
But i used servo and a 555 timer ic another remote and a lever to trigger
great project
This should keep the kids from grabbing my pumpkin and smashing it in the street !!
They'd probably just turn the thing around, around here anyways.
Blast wouldn't be as long, but steps would be much easier.
More dangerous and would need to put completely away from access (like on roof) cause it will go off on it's own.
http://www.wd40.com/uses-tips/
