iImage Information
Vector Illustration is often quite hard to wrap ye old noggin around sometimes - especially for beginners. Whilst most Illustrators tend to use the larger more orthodox illustration applications such as Adobe Illustrator and Freehand , I choose to use Flash because of its simple, and animation friendly drawing tools. I plan to write a few of these, but first I want to lay down the basics before I even write about shading and tone, so yeaaaaaaaah! Of course, everything that appears within this tutorial can easily be accomplished using alternative packages - I will walk through my general work flow for the sake of the tutorial, and be covering the process used to create the illustration you see of steve getting attacked my the octopus.
Step 1Get the right gear!
iImage Information
Ok enough jibber jabbering. For this tutorial, all you will need is Flash, and a drawing to work from. I recommend a scanned rough, or something sketched up in Photoshop or Alias Sketchbook (what I usually use). I will mention that a drawing tablet is definitely desirable in order to achieve accurate line work, and also make the process quicker (tablets are ninja quick).
