Step 2Sketch it up!
iImage Information
Before you even pop open Flash you should always rough out the concept first. Even if it is simple blocks and elements to establish the composition. The more messing around you do at the start determines how much tweaking and tedious refinements you will need to apply to your final product. Often, I will really loosely draw elements a few times until I get the general feel of them, and start layering the roughs on top of each other until I have a nice and balanced form. In the octopus sketch above, it is a little more detailed than I usually would attack a drawing, because it was being used for a project. Nevertheless, if you detail your image in the beginning, it means you will not have to worry about adding and touching your vectored line work when colouring and shading.
