Introduction: Flash Light Holder
this is an easy way to make a flashlight holder that you can use to hold a flashlight on your head
Step 1: What You Need
this is what you need
(you will also need a twist tie)
Step 2: Preparing the Flash Light
take the clip off the flashlight if it has one
Step 3: Making the Case Part 1
cut out pieces of duct tape as long as the handle and roll them onto the handle sticky side up
Step 4: Making the Case Part 2
roll on pieces of tape sticky side down onto the tape
Step 5: Attach the Case Onto the Strap
put zip ties under the flash light and tighten them. Then you cut off the ends
Step 6: Making Sure That the Flashlight Doesn't Fall Out Part 1
you can only do this if the flashlight has a hole in the back
cut out the tape and put it on the flashlight holder covering the zip ties
Step 7: Making Sure the Flashlight Doesn't Fall Out Part 2
put a twist tie through the hole.
cut out a piece of tape.
start to roll on a piece of tape.
fold over the end.
finish rolling on the tape.
Finished
If you have any questions leave me a comment.
please vote for me if you like it.
Flashlight Contest
