Flashing "BONEfones" by gschoppe
Convert a totally underwhelming foam skull into a Halloween speaker system.
-=Backstory=-
I was at Abott's party store in Littleton, NH a couple days ago and saw a foam skull. Upon first glance it looked like your basic Halloween prop, until I saw the LEDs in its eyes. I immediately knew this would be the prop of a lifetime... with the sort of technology it was hiding in its cranium, the skull might be able to:
a) Scare the daylights outa the neighborhood kids
b) Dispense fortunes when it detected questions directed at it
c) Do the dishes, walk the dog and fetch me a beer
d) All of the above
With visions of sugarplums dancing in my head, I reached down with hands trembling in anticipation and flicked the "ON" switch.
Its eyes lit up.
they didn't even blink.
I was utterly devestated.
It was then and there that I decided to remedy this great injustice. I purchased the skull and began brainstorming.
Ten Redbulls later I hit upon an idea...
What if the skull could talk...
what if his eyes lit up while he talked...
Brilliant!
so I set to work...
Step 1: Gathering Materials & Disassembling
I used the following materials for my skull:
note: double all amounts for stereo setup
1x foam skull with led eyes ($12.99)
1x 8ohm speaker (scavenged)
1x TIP31 npn transistor ($1.59 at radioshack, :( )
1x 1/8th inch mono phone jack (6 for $3.99 at radioshack :( )
1x stereo to mono 1/8th inch adapter ($2.99)
lots of thin wire (scavenged from a previously mutilated usb cable)
soldering skills
The first step is to remove the four screws holding the base on and snip the wires to the leds, leaving a stripable amount attached to both the LEDS and the battery box
Step 2: Build Circuit
build the circuit shown below from your components...
Their are two essential, traceable circuits in the overall diagram they should go as follows
Light Circuit:
positive terminal of battery box unit goes to LEDs (in series)
negative terminals of LEDs go to transistor's Collector pin
transistor's Emitter pin goes to battery box unit's negative terminal
Controller Circuit:
Positive terminal of phono jack goes to speaker and transistor's Base
Negative terminal of phono jack goes to speaker and transistor's Emitter
Step 3: Drill Skull - Mount Adapter
drill a hole in the back of the skull's cranium about 3/8th inch in diameter and enlarge it slowly until the first 3/4 of the stereo to mono adapter fit snugly. Then hammer the adapter into the foam until flush with the skull. It should form an extremely tight press fit.
Step 4: Mount Speaker
you could use pins, epoxy or short screws...
I used hot glue.
forgive me.
Step 6: Close, Suture, and Test
re-assemble the skull and attach to a powered audio source (headphone or speaker jack) the skull's eyes should pulse with changes in volume.
For stereo action, you'll need to create a second skull and a special patch cable...
for the patch cable cut the cord of a set of headphones, seperate the left and right channel's wires and attach a mono phono jack to each channel
I found that the sound source needs to be pretty loud, so a Boostaroo or similar headphone amp is a godsend, but a loud audio file works just as well.
now for Ideas for use:
1) connect to aux out at a halloween party and place accordingly (on speakers, mantel, table, ect)
2) connect to mini fm radio and use a tunecast-style transmitter to play selected clips
3) mount on mannequin in grim reaper robes
4) connect to PC and use a webcam as a motion detector to play selected messages
5) Paint metallic silver and mount on hydrolic skeleton to create a working t1000 series robot... then send it back in time to protect Sarah Connor and stop the rise of SkyNet
Have fun!!
riverreaper says: Jul 25, 2010. 12:20 PM
could you post a movie ? it say flashing but we cant tell that from pic ,ive set of lights that will flash if box is bumped slighly , a phones vibration would set them off some red plastic in the eyes would be glowing now ive to find scules 3 months befor the day of lol
BigMatt.ZA says: Jun 2, 2007. 3:50 AM
im confused, is this so you can talk throught the skulls and scare the sh*t out of people....cos thats cool and all, but as pc speakers it would rock evn more.
Thunderexpress says: Mar 22, 2007. 4:04 PM
scavenge it boy.
Neech says: Oct 18, 2006. 3:48 PM
Sweet idea, I want one. What did you use for your power supply? 3V - 2AA? Why does your ciruit have the diodes in parellel?
gschoppe (author) says: Jan 5, 2007. 4:16 PM
they're in parallel because thats the way the skull was already made... if you made your own, you'd want them in series
Junkernaut says: Oct 19, 2006. 4:52 PM
Sweet Halloween Idea. that looks like you could make a iskull ipod dock
Neech says: Oct 18, 2006. 3:49 PM
Robotrix says: Oct 12, 2006. 10:43 AM
I applaud your commitment to giving halloween props the respect and ingenuity they deserve
gschoppe (author) says: Oct 11, 2006. 10:01 PM
Just to give credit where due, I chose my transistor based partly on its use in the blinking led project at:
http://www.instructables.com/id/E1K7SJ2ZG6ERIE36TP/?ALLSTEPS
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
