I recently purchased a old Chevy Pickup and wanted to add a flashing LED. I already had my Zombie friend in the truck, so I thought I would add him into the mix. The thought was to use the normally closed contact of a 12 volt relay to power a flashing red LED and the normally open contacts to illuminate the Zombie with a white or green LED. When the truck is off the red LED flashes and when the truck is running the Zombie glows bright green. The added bonus is the Zombie glows in the dark, so he is all charged up after a drive.
BE CAREFUL WHEN DRILLING HOLES AND WORKING WITH THE 12 VOLT POSITIVE BATTERY LEAD. ATTEMPT AT YOUR OWN RISK, THE AUTHOR IS NOT RESPONSIBLE FOR YOU BLOWING YOUR AIRBAG BY TAPPING INTO THE WRONG WIRE, OR DRILLING A HOLE IN YOUR ECU, OR SETTING YOUR CAR ON FIRE, ETC...
Remove these ads by
Signing UpStep 1Tools and Supplies
- Wire Strippers
- Wire Cutters
- Crimpers
- 4' of 22 gauge wire (red)
- 4' of 22 gauge wire (black)
- 4' of 22 gauge wire (yellow or orange) This is optional, but I think it is a good idea to use a color other than red for the key on power (accessory).
- Five crimp on female spade connectors for relay connection(Radio Shack, Fry's).
- One crimp on eyelet connector for ground connection(Radio Shack, Fry's).
- Terminal Strip with at least 4 sections (Radio Shack, Fry's).
- Fuse and fuse holder if you are coming straight off the battery (Radio Shack, Fry's).
- Heat shrink (assorted sizes) (Radio Shack, Fry's).
- One Linrose Flashing Red LED 12 volt (Fry's).
- One Linrose Super Bright Green LED {3.2Vf-20mA-10 Candela "sunburst series"} (Fry's) Could substitute other color.
- One 680 Ohm resistor 1/2 watt (Radio Shack, Fry's).
- One 12 Volt Bosch Automotive Relay, Single Pole Double Throw {SPDT} (Radio Shack, Fry's).
- One Glow in the Dark Zombie Finger Puppet (Amazon).
- Small Project Box (Radio Shack, Fry's).
comments
Add Comment
scoochmaroo
says:
axlejor (author)
says:
Add Comment
