3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flashing Tesseract Ornament
The ornament described herein is a tesseract or 3-d representation of a 4-d object.
The ultimate in Geek ornamentation.
I was trying to achieve the look of the one pictured at this link, but was having difficulties with the tools and supplies I had.
Step 1Tools, equipment, supplies and componants
For the Big outer box, I used an almost cube shaped baseball or trinket display case I bought at a craft supply store.
For the smaller box, I could not find something suitable, so I made one using he corners cut out of a clear rectangular box (cuboid) and clear glued back together.
Other thing the boxes and glue, I used:
One 9v battery clip,
one 110 ohm resistor,
one small on/off switch,
2 lengths of magnet (coil) wire,
3 LEDs (one was a self blinking type)
hot glue (and so a hot glue gun is appropriate also),
a soldering iron and some solder,
some conductive glue (although you can also run the magnet wire along edges and paint      a gold color to hide it)
A compass (no, not the kind that points north, the kind used to draw arcs and circles),
  OR a protractor,
The formula for figuring out the length of the "connecting legs"
and a LOT of patience.  Of course, if you have worked with hot glue before, you probably
     already have some of that.
The formula is courtesy of BrittLiv and Kelseymh.   It depicts the square root of 3 divided by 2 * (b - a)
Or as explained by Kelseymh:
  sqrt(3)
   -------     * (b - a)
14 comments
Dec 26, 2010. 2:24 PMkelseymh says:
Nice project! Only one minor comment, which you may want to fix on the graphical version of Step 1: The formula is sqrt(3)/2 * (b - a). You've got a and b inside the radicals, which isn't right.
Jan 6, 2011. 11:27 AMkelseymh says:
Yes, but it's really hard to read (lots of surrounding whitespace made the characters really small. You might just want to write it as
sqrt(3)
------- (b - a)
which is pretty standard mathematical notation.
Dec 28, 2010. 1:58 PMChrysN says:
Neat! Gotta love an ornament that requires a mathematical formula to make it.
Dec 29, 2010. 6:08 PMChrysN says:
I saw Cube, but I didn't realize there was a sequel. I should check it out.
Dec 26, 2010. 8:27 AMDr. Pepper says:
Amazing, love your project.
Dec 26, 2010. 1:26 AMlemonie says:
Interesting, do you think you could scale-up to this?
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
137
Author:Goodhart(Old as the hills...)
I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time... My two "spe...
more »
