This project is from my book Haywired
Click here to order a copy from the Chicago Review Press.
Parts List
(2) 220 farad capacitors, www.digikey.com, #589-1013-nd
Insulated wire, black and red
Solder
LED, high brightness, www.jameco.com, #217525
12" x 12" acrylic plastic sheet, 1/8" thick
Permanent marker
(2) C clamps
Epoxy
1/4" jack, Radio Shack, #374-280
Metallic tape
SPST rocker switch, Radio Shack, #275-693
Glue
Electrical Tape
Tools List
Wire cutters
Soldering Iron
Scoring knife (for plastic)
Single-hole paper punch
3-volt DC power supply--700 milliamp
Drill
1/4", 1/16", and 3/4" drill bits
Metal straightedge
Remove these ads by
Signing UpStep 1Put capacitors in series
very nice
http://www.instructables.com/id/2600-Farad-Capacitor-Flashlight/
Here is the link plus the link to instructions, diagrams, and pictures of the flashlight.
http://s247.photobucket.com/albums/gg153/luxstar/
http://www.goldmine-elec.com/
Anyone know if I have to use an AC/DC rectifier to sort out the charge?
On what you have here, if you reverse the voltage and/or exceed the voltage rating on the caps and this is a potential bomb that will send shards of plastic flying everywhere.
If you can determine the "ohm equivalent" of your load, then the formula, T=RC where T=time (in seconds), R= resistance in ohms and C=capacitance in farads; then T will be approximately how long your capacitors will supply some power to your load. For example, if your load is 1000 ohms and you are using a 1000 microfarad capacitor (1000 X .001 =1) then the power will last about 1 second. This is the reason that you need capacitors with farads (not microfarads) of capacity to power anything for very long.
That being said, what you have will work--but only for a few seconds.
Hopefully, it inspires people to buy your book!
i couldn't help but to think how cool it would be to add some solar cells in that clear case, though!
it so easy and educational ha....
Can i use only a 1F capacitors..??
One capacitor (usually rated around 2.2volts) will be damaged if you charge it to a high enough voltage (around 3.5 volts) to light the led.
i got only micro once plz reply that what i sould keep.
Only downside to these is the max voltage going through all of them is 5V in series (so 2 max in series). Putting them in parallel pairs, however, you can probably come close to matching to this instructable.
ah excuse me but WTF DO YOU FIND A 220 FARAD CAPACITOR
but yeh this rules no probs with batteries leaking and quick charge time
i wonder if you could add a car adaptor
