loading
In this project, you will make a flashlight that works without batteries. Even more amazing, you can recharge it in three minutes and it will run for more than 24 hours. Because the ultra capacitors can be recharged thousands of times, you may save the environment from ever receiving an old flashlight in the trash system.
This project is from my book Haywired
Click here to order a copy from the Chicago Review Press.
Parts List
(2) 220 farad capacitors, www.digikey.com, #589-1013-nd
Insulated wire, black and red
Solder
LED, high brightness, www.jameco.com, #217525
12" x 12" acrylic plastic sheet, 1/8" thick
Permanent marker
(2) C clamps
Epoxy
1/4" jack, Radio Shack, #374-280
Metallic tape
SPST rocker switch, Radio Shack, #275-693
Glue
Electrical Tape
Tools List
Wire cutters
Soldering Iron
Scoring knife (for plastic)
Single-hole paper punch
3-volt DC power supply--700 milliamp
Drill
1/4", 1/16", and 3/4" drill bits
Metal straightedge
Step 1: Put capacitors in series
First, solder a wire from the (+) on one capacitor to the (-) on the other capacitor.
Step 2: Solder wire to (+)
Solder a 4-inch length of red wire to the unused (+) terminal on the capacitor. You will call this capacitor wire (+).
Step 3: Solder wire to (-).
Solder a 2-inch length of black wire to the unused (-) terminal on the capacitor. You will call this capacitor wire (-).
Step 4: Correct method to cut plastic
Next cut the 1/8-inch plastic sheet for the flashlight case. Generally, this is accomplished by scoring the plastic, then breaking it along scored lines. But first, mark the plastic with a marker, then use the C clamp to hold a metal straight-edge next to the mark. Then use the tip of a scoring knife (usually sold next to the plastic sheets) to create a fine groove in the plastic along the line you marked.
Step 5: Scoring Plastic
Using the scoring edge (not the knife tip) pull the knife along the fine line several times until you create a groove. The plastic can now be snapped along the score line. Practice this method a few times until you master the technique.
Step 6: Start the case
Now you're ready to build your flashlight case. First, cut out three 1 1/4 x 7 inch pieces of plastic and glue them together with epoxy. This is the flashlight body.
Step 7: Install jack
Cut a plastic piece 1 1/4 inches by 1 1/2 inches. Drill a 1/4-inch hole and insert the 1/4-inch jack. Hold the jack with one hand (to prevent it from rotating) while threading the nut and washer.
Step 8: Add wires to jack
Solder a 2-inch-long black wire to the end of the jack near the tab. Solder a 3-inch-long red wire to the other side of the jack (away from the tab).
Step 9: Attach jack to capacitor
Solder the red wire from the jack to the capacitor (+). Solder the black wire from the jack to capacitor (-). These wires form the path that will be used to charge the capacitors.
Step 10: Prepare for LED
Cut a piece of plastic, 1 x 1 1/4 inches. Drill two 1/16-inch holes in the center, side by side, the same distance apart as the leads on the LED. Cut a piece of metallic tape, 1 x 1 1/4 inches. Punch a hole in the center of this tape using a hole punch.
Step 11: Place reflector and LED
Remove the paper backing from the tape and fasten the tape to the plastic. This is part of the reflector for the flashlight. Insert the LED leads through the holes.
Step 12: On Off switch
Cut a piece of plastic 7 inches by 1 1/4 inches. Drill a 3/4 inch hole 2 1/4 inches from the end. This is the plastic switch holder. Press the on/off switch through the hole and secure it by threading the switch's plastic nut.
Step 13: Attach wire to switch
Solder one end of a 6-inch length of black wire to one end of the capacitor (-). Solder the other end to the on/off switch.
Step 14: Capacitor (+) to LED
Solder the wire from capacitor (+) to the long lead of the LED.
Step 15: LED to on/off switch
Cut a 2-inch length of red wire. Solder one end to the short lead on the LED. Solder the other end to the on/off switch.
Step 16: Glue jack piece to flashlight body
When the switch is on, power will flow from capacitor (+) through the LED, through the switch, back to capacitor (-). This will cause the LED to light up. Carefully place the capacitors and the jack into the flashlight body. Glue the jack piece onto the end of the flashlight body.
Step 17: Separated jack and capacitor
Cut a 1 by 3/4 inch piece of plastic. Insert it into the flashlight body, between the jack and the capacitor. This will prevent the capacitor from sliding into the jack; thus avoiding a potential short circuit
Step 18: Cover on/off switch wires
Place electrical tape over the on/off switch wires.
Step 19: Glue LED holder
Glue the LED holder into the flashlight body.
Step 20: Form reflector
Place metallic tape inside the flashlight body and on the plastic switch holder to form the reflector.
Step 21: Finish assembly
Glue the plastic switch holder to the flashlight body. Cut a 1 1/2 x 1 1/4 inch piece of plastic for the lens. Glue the lens in front of the LED.
Step 22: Charge and use
Plug a 3-volt DC power supply, (+) tip, into the back for three minutes. Remove the power supply and enjoy your new flashlight.
I just saw the Tecate website. The caps the have are balanced they say so there is no need for external regulation. Did I get that right? Am I to understand there is no need for current limiting or is the circuit just to protect the caps. If you get a big enough cap bank and a wind generator you could power your house without batteries. Or maybe from Lightening Bolts!! YEAH THATS IT!! I LIKE LIGHTENING!!!!!!!!!!!!
Ha! When I was running Squid Labs, prior to Instructables, we once got a proposal to design lightning-powered electricity plants. The potential client said that he was sure there was a tremendous amount of energy in each lightning bolt, and that if we could just figure out a way to capture and distribute that energy, we could both be rich (he was willing to split all future profits related to his "idea" in return for our work actually developing the system).
Ben Franklin (never known as Mr. Safety) came up with a system to let him know about upcoming electrical storms (so he could go out and play). Known as Franklin's Bells, this is probably not advisable around buildings or people you ever want to see again. However, using an old tube type computer monitor (or your old analog tube tv), you can simulate Mr. Franklin's work. Look at <br/><a rel="nofollow" href="http://video.search.yahoo.com/video/play?p=franklin+bells&amp;ei=UTF-8&amp;fr=yfp-t-501&amp;fr2=tab-web&amp;tnr=21&amp;vid=0001146035835">http://video.search.yahoo.com/video/play?p=franklin+bells&amp;ei=UTF-8&amp;fr=yfp-t-501&amp;fr2=tab-web&amp;tnr=21&amp;vid=0001146035835</a><br/>to see how this can work. Search &quot;Franklins Bells&quot; for more information.<br/>
There is a battery pile that was made in the 1700's. It had a brass ball hanging on a bar at the top from a silk thread down between 2 brass bells that would just ring all the time. Well, it's still ringing today and it is part of a collection belonging to Yale University. Cool Huh ?
I think you are thinking of the Oxford Electric Bell running off of two Zamboni Pile batteries. The bell was started in 1840.
<p>There is one at Yale doing the same thing.</p>
<p>I really want to try this project! But can someone please tell me where to get the capacitors?!?</p>
<p>Try Digikey--here's one that will work</p><p>http://www.digikey.com/product-detail/en/BCAP0310%20P270%20T10/1182-1015-ND/3079279</p>
I've been searching everywhere for these. Thank you so much! They should work similarly correct?
<p>They should be similar--may be a different physical size. They have more capacity, so should cause the light to illuminate longer.</p>
<p>Ok great! Thanks!</p>
Nice job
Comprehensive instructions, but you are lucky to find the LED not burning out if you don't use a current limiting resistor in series with it. LEDs are very sensitive to over-voltage. The cheap battery LED lights you get often don't have a dropper resistor to save money but they rely on the internal resistance of the battery limiting the current. The problem here for others copying this design is that they could have an LED which needs less than 3v and, because the supercap can deliver large currents, it will blow the LED. There are lots of sites which will let you put in the driving voltage, the LED voltage and the LED current and give you the value of the current limiter resistor. <br> <br>It might also be a good idea to use a current limiting resistor in the charging circuit also, to limit the current when the capacitor is empty in order to not fuse or blow up the PSU. An uncharged supercap is effectively the same a s a short circuit across the PSU which may blow up an unprotected or fused PSU. Charging from batteries, this is less of a problem due to their internal resistance.
Hey Guys! I made a drawing of it: <br> <br>
how long does it last
It's good for an hour or so at reasonable brightness--but it will continue to produce light for 24 hours or more.
cool man i like
i tried it <br> very nice
done.. Here is the link to the 2600 farad flashlight instructable:<br><br>https://www.instructables.com/id/2600-Farad-Capacitor-Flashlight/
Anyone interested in supercapacitor projects should look at this--and follow the links to suppliers. Luxstar has pointed out the best price for big caps that I have heard of!
I recently made a supercapacitor flashlight that requires no batteries. I charge it off of a 5 watt solar panel. The larger capacitors of this type are usally quite expensive but the $10.00 2600 farad capacitors are back for now (on home page of Goldmine-Elec plus others on boost cap page). <br>Here is the link plus the link to instructions, diagrams, and pictures of the flashlight. <br>http://s247.photobucket.com/albums/gg153/luxstar/ <br>http://www.goldmine-elec.com/ <br>
Great resource! Thanks for sharing.
Working on adding the pictures
that looks pretty sweet....how long does the light work?
It shines brightly for two or three hours--but shines enough to be a night light for 36 hours or longer.
wow! thats awesome
Holy ****, you can get 220F capacitors? I kind of want to get five so I can have a kilofarad- there's a certain geek pride in breaking a new unit like the terabyte or the petaflop :) I make a 220F capacitor at 3V almost exactly 10,000J, which is 3,333 amp seconds or about 925 mAh. Given an average NiMH AAA battery has 900mAh, that makes one of these capacitors roughly equivalent to two NiMH AAA batteries! And it recharges in a couple of minutes! I need to get a couple of these for my MP3 player... we live in the future :)
Whoa...that sounded like geek jargon flying at me at over 9,700,300.284 miles a milisecond!...lol...so im just gonna shake my head up and down and act like i understand...
Hehehe sorry, I have a tendency to work out stuff like this to make it clearer in my own head (but possibly less clear in everyone else's :P). If you ignore the &quot;show your working&quot; part in the middle, I just figured out that each one of these capacitors can hold the same amount of energy as two rechargeable AAA batteries, which is pretty impressive for a capacitor.<br/><br/><sub>yeah ignore the bit about kilofarads as well..</sub><br/>
Try out this place:<br/><a rel="nofollow" href="http://www.tecategroup.com/ultracapacitors/productfinder.php">http://www.tecategroup.com/ultracapacitors/productfinder.php</a><br/>I purchased some really large capacitors for another project.<br/>
How do you charge a capacitor that is rated at 350 farad 2.7 volts any one know cause i don't know is it's safe to charge it wiht a 15 volt power supply.
&nbsp;Digikey stopped selling the ultra capacitors anywhere else I can find them<br /> <br />
www.electroniclessons.com will take you to an ebay store that sells all sorts of them. DC-DC boosters as well.
Seems like this needs to be hooked up to an induction generator, to really make it an emergency flashlight.<br /> <br /> Anyone know if I have to use an AC/DC rectifier to sort out the charge?<br />
To charge this circuit using even a good DC crank would take a heck of a long time, and it would result in an extremely sore arm =s
This circuit seems potentially <strong>very </strong>dangerous to me. I think there needs to be at least one diode between the voltage input and the capacitors to limit electron flow in one direction and with a voltage rating less than the capacitors. <br/><br/>On what you have here, if you reverse the voltage and/or exceed the voltage rating on the caps and this is a potential bomb that will send shards of plastic flying everywhere.<br/><br/>
If his input voltage is 3VDC, then he's not going to over-charge the caps. I'd be more concerned for the input source with no limiting resistors in series with the caps. That's a good way of destroying your wall wart,
Are you suggesting that in any circuits it is better to use a diode between the voltage source and the capacitors? if we should add diodes to prevent from any accidents in a circuit in what all conditions and with what all components should we do that? It would be very kind of you to reply me............
If you choose to Use a diode, it should have a higher voltage rating than the capacitors and it should be able to handle as much current as your power supply provides. If you power supply has diodes on the output (and no capacitors beyond the diodes), then you probably don't need an additional diode. Although these capacitors store a lot of energy (for a capacitor), it's less energy than a &quot;aaa&quot; battery.
So how is run time determined by ferrad like if i have a 100uF cap it will last less and if i use 100F it will last longer is these right?
Yes, the larger the amount of farads, the longer it will last. <br><br>If you can determine the &quot;ohm equivalent&quot; of your load, then the formula, T=RC where T=time (in seconds), R= resistance in ohms and C=capacitance in farads; then T will be approximately how long your capacitors will supply some power to your load. For example, if your load is 1000 ohms and you are using a 1000 microfarad capacitor (1000 X .001 =1) then the power will last about 1 second. This is the reason that you need capacitors with farads (not microfarads) of capacity to power anything for very long.
Hi, can I make this work with 2 1000 microfarad 200wv capacitors?
The capacitors I suggested (in series) are the equivalent of one hundred ten million microfarads--so your capacitors are about 1/10000 of the storage.<br><br>That being said, what you have will work--but only for a few seconds.
Great Instructable! Thank you for sharing it!<br>Hopefully, it inspires people to buy your book!<br><br>i couldn't help but to think how cool it would be to add some solar cells in that clear case, though!
such a great idea or i called invention<br> it so easy and educational ha....
Thank u very much for your response..... I have been doing a project on the topic RPS. So I made one. The specifications for it is (0-12)V. Since it is of variable type I used a LM317 regulator for it. The problem is I'm getting an output voltage range from (1.4-12)V but i should get from (0-12)V. After browsing thro' the Internet i found that diodes can be used in the circuit for that purpose but still, i don't know where to connect the diodes in the circuit to get the result........ I'm looking forward to your reply...........
Am I missing something here or are you effectively halving your capacitance by putting them in series One on its own 220 F Two in parallel 440 F Two in series 110 F (in the instructable they're in series?)
I'm going in series to boost the voltage--2.5 volts is not enough to operate a white led (unless you add some circuitry, which is certainly a reasonable--though more complex option). It's actually the same power delivery, because doubling the voltage results in 4 times as much power delivered to a fixed (ohm) load.
I don't think so brother, because this led light consumes very minimal power. You can even light up an old school red led with a 1k resistor without charging it.&nbsp; On the other hand, laptop as we know consumes more power, given the motor in the hard drive, the fan for the CPU and not to mention the back light for the LCD. Now most laptops, especially the new ones has lithium in the battery where the charge is stored that's how it sustains the need for power. However about the lifespan of the battery, I would say that one year is the normal life span of a laptop battery. I should know, 'cause I work for a computer company. :-) <br />
About This Instructable
141,399views
323favorites
License:
Bio: I am an author and a maker. Current projects include Santa's Shop and Little Friend (ultracapacitor powered robot) on hackaday.io. I'm working ... More »
More by MikeTheMaker:Noisy Train Pretty Useless Machine LED Reindeer Tea Light Holder
Add instructable to:
