3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flashlight Without Batteries--from the book, "Haywired"
Step 9Attach jack to capacitor
Solder the red wire from the jack to the capacitor (+). Solder the black wire from the jack to capacitor (-). These wires form the path that will be used to charge the capacitors.
4 comments
Mar 24, 2009. 7:15 AMLazarusTree says:
This circuit seems potentially very dangerous to me. I think there needs to be at least one diode between the voltage input and the capacitors to limit electron flow in one direction and with a voltage rating less than the capacitors.
On what you have here, if you reverse the voltage and/or exceed the voltage rating on the caps and this is a potential bomb that will send shards of plastic flying everywhere.
Mar 28, 2011. 5:21 AMEngineeringShock says:
If his input voltage is 3VDC, then he's not going to over-charge the caps. I'd be more concerned for the input source with no limiting resistors in series with the caps. That's a good way of destroying your wall wart,
Aug 27, 2010. 4:48 AMshobanaelango says:
Are you suggesting that in any circuits it is better to use a diode between the voltage source and the capacitors? if we should add diodes to prevent from any accidents in a circuit in what all conditions and with what all components should we do that? It would be very kind of you to reply me............
Aug 27, 2010. 10:43 PMshobanaelango says:
Thank u very much for your response..... I have been doing a project on the topic RPS. So I made one. The specifications for it is (0-12)V. Since it is of variable type I used a LM317 regulator for it. The problem is I'm getting an output voltage range from (1.4-12)V but i should get from (0-12)V. After browsing thro' the Internet i found that diodes can be used in the circuit for that purpose but still, i don't know where to connect the diodes in the circuit to get the result........ I'm looking forward to your reply...........
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:mrigsby(Home made iPad apps)
Picture book series for kids age 3 to 7. "Phil and Freddy's Picnic" now free. I've also written an app, "How To Make A Science Fair Project." I am the author of "Doable Renewables," "Haywired" an...
more »
