Step 14Putting it all together
Finally it is time to put everything together:
(in my line-up picture I forgot the push-button acrylic)
- Start with het bottom U-profile
- Put in the four bolts
- Add the two acrylic strips and the piece with the hole for the battery in the middle.
- Place the battery with the - (minus) of the battery down, touching the bear aluminum.
- Ad the thin sheet of plastic.
- Fasten with four nuts.
- Put a piece of foam-tape on the thin sheet of plastic where the side of the battery is underneath it.
- Put the PCB halfway on it.
- Strip the end of the wire coming from the on/off button.
- Bend the wire in a zig-zag and put it trough the fifth hole in the plastic sheet to touch the top (+) of the battery (under the piece of foam-tape)
- Push the PCB all the way down.
- Make sure that the bear wire coming from the GND on the PCB, touches the side of the housing and is wrapped around the bolt, to make a good ground-contact.
- Put the on/off button in place. (make sure all the wires aren't in the way of something like a button or sensor)
- Turn it on and see if it works... ...Yes!!!
- Add the push-button acrylic. (it just lays on top of the PCB)
- Put the top-enclosure on it.
- Just four more nuts.
Add Comment
