3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flashlight tag
Step 4Designing the PCB
Designing the PCB
The design software
To design the PCB, I use Fritzing: It is open source and it fits the Arduino way of life.
Check out: www.fritzing.org
The design
Designing a PCB in Fritzing is easier than you might think. I won't say that it isn't a challenge, but just try it, it is fun.
First you put all the components in the breadboard in the breadboard-view. You just place them exactly as you did in the real world.
Next you go to the PCB-view and you will see that this view really is a mess. You now arrange the components how you would like them on your PCB. Now you click autoroute and the magic happens. It is never exactly right the first time. Sometimes it just helps to click autoroute again and sometimes you have to move, turn or change some parts. You can also draw your own copper.
(this is not a Fritzing tutorial, there are many on the web)
(I added the actual Fritzing file I made, so you can play with it)
Exporting your design
Now you can export your design. (if you don't want to etch your own PCB, you can also order the PCB directly from the Fritzing program) But I will be etching my own PCB, so I will export it for etching. This will result in a nice PDF-file. Doesn't it look cool.
Printing your design
To print your design, you will need a laser-printer. A bubble-jet won't do. First I use a vector-drawing program to put more than one PCB on one sheet of paper. You could use a program like Adobe Illustrator. My legal version of Illustrator doesn't work anymore (since I'm running Lion), so I use Inkscape. This is also a free program. See www.inkscape.org.
Now I first print on a normal sheet of paper and look wether the parts will fit. My printer makes the designs slightly smaller than they should so I have to print my designs 103%. Just check what your printer does.
If the size is right, you can get your 3M transparent sheet en print your design on that.
3 comments
Dec 15, 2011. 3:09 PMdiy_bloke says:
Interessante instructable. Waar haal jij eigenlijk je ATtiny's? Mijn lokale electronica zaak vraagt er 6.50 voor. Haast goedkoper om ze in Amerika te bestellen.
Dec 16, 2011. 12:59 AMdiy_bloke says:
Fantastisch. Dank!
Jan 6, 2012. 1:24 PMjanw says:
smdshop.nl voor smd versies van de attiny45. Hier zijn ze nog goedkoper en goede service.
Jan 6, 2012. 2:52 PMdiy_bloke says:
Bedankt janw. Altijd goed om zo'n adresje te hebben
Jan 6, 2012. 3:02 PMjanw says:
Je maakt je eigen PCB's dus dan is de overstap naar smd niet moeilijk.
Ik heb lang met een gewone soldeerbout en tin smd componenten gesoldeerd en het is supergoed te doen (al mijn instructables projecten die smd bevatten zijn met een gewone bout gesoldeerd).
Nu gebruik ik meestal soldeerpasta en een hetelucht-soldeerapparaat.
Jan 6, 2012. 2:55 PMdiy_bloke says:
mijn ogen zijn niet meer zo goed, maar voor een klein projectje is het wellicht erg handig :-)
Jan 6, 2012. 2:58 PMjanw says:
een vergrootglas doet wonderen!
Jan 6, 2012. 3:14 PMdiy_bloke says:
Haha, ik ben in een stadium dat ik al een fikse loupe mout gebruiken. :-)
Hoe dan ook, ik heb net een smd Scottky diode gekocht om op mijn Arduino nano bordje te solderen (ja, kortsluiting gemaakt) eens kijken hoe dat gaat. Ik heb denk ik 30 jaar geleden voor het laatst smd gesoldeerd.
Omdat de Scottky in het bordje colkomen kapot is, is het misschien het makkelijkst om de nieuwe er met een druppeltje lijm op vast te lijmen en dan da kantjes te solderen.
Heb even wat prijzen vergeleken:
attiny45 smd. SMD shop 2.15 Dickbest 2.50
attiny2313-20PU smd SMDshop 2.49 (soic20) dickbest 2.00 (sol20) 1.95 (DIL).
Soms dus de een soms de ander goedkoper. Dickbest heeft als minimumorder 6 euro en de verzendkosten zijn laag. Bij smd.shop weet ik dat niet. SMD shop heeft wel een groter assortiment Atmel microcontrollers.
Beide lijken me handige adressen om te hebben. Bedankt
Jan 7, 2012. 2:19 AMjanw says:
Het klopt dat ze qua prijzen ongeveer hetzelfde zitten en ook de verzendkosten zijn vergelijkbaar. SMDshop heeft wel geen minimumbedrag. Vroeger had dickbest bijna geen smd (dat is nu wel verbeterd) en daardoor ben ik bij smdshop terechtgekomen. Hij heeft ook kleine klinknageltjes waamee je gaten in zelfgemaakte PCB's kan doormetaliseren en dat is echt heeeeeeeeeeeel handig.
Jan 7, 2012. 3:10 AMdiy_bloke says:
ah, die zocht ik net. Fantastisch. Dank zij jou en kenyer ben ik weer een heel stuk verder.
Jan 7, 2012. 5:49 AMjanw says:
Het is inderdaad voor dubbelzijdige PCB's maar ook als je onderdelen wil solderen waarbij je bvb niet aan de soldeerpads kan doordat het onderdeel er overheen komt. Dan kan je met behulp van zo'n busje dat onderdeel aan de andere kant solderen. Bij dubelzijdige PCB's kan je natuurlijk ook gewoon een draadje gebruiken om van de ene naar de andere kant te gaan maar ik vind zo'n klinknageltje netter.
Jan 7, 2012. 6:22 AMdiy_bloke says:
Ik gebruik die busjes inderdaad als ik bijvoorbeeld printpennen aan de onderkant van een printje wil solderen. Dat gaat met die busjes uitstekend
Dec 15, 2011. 8:02 AMBob Sutton says:
Don't give up on your legal copy of Illustrator with OS X Lion yet! Here's a thread that describes an easy fix that solves printing issues for several Adobe CS apps: http://forums.adobe.com/thread/879762?start=50&tstart=0. I tried it and Illustrator works again as it did pre-Lion.
Nice project, by the way!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:kenyer(Technisch Speelgoed)
I'm a social-worker, working with 16 - 23 year-olds. I used to be a printer and I worked voluntarily in Romania for a couple of years. One day a week I have a toy-store in technical toys. I have this ...
more »
