Introduction: Flat Folder for Papercrafting
Picture of Flat Folder for Papercrafting
This simple tool makes paper creases clean and sharp. I've found it to be indispensable in bookbinding, scrapbooking, and origami projects. I used to use the handle of scissors or a table knife to flatten creases, but this is better. Plus, it takes about half an hour to make if you have some sort of power-sander.
If you don't have any power-sanding equipment:
A) Don't worry...Plain sandpaper works.
B) Check out TechShop! Scads of tools are available to members. That's right, I made this at Techshop.
Tools & Materials:
1: Scrap wood 1/4-3/4" thick and no smaller than a credit card (hardwood is best; plywood will work)
2: Sandpaper, 60-220 grit
3: OPTIONAL: orbital, belt, or disc sander (with sandpaper in appropriate grits)
4: OPTIONAL: drill or equivalent; cord or chain
Step 1: Choose & Trim Wood
Picture of Choose & Trim Wood
We're basically making a big blunt blade for flattening paper. It can be of any material that won't crumble or break or scratch and stain the paper.
I had some 3"x4" maple trim samples sitting around. I got them free at Zerolandfill. They were painted black on the edges and had a bevel on one side, but that doesn't matter.
So see what you have lying around the shop and trim it into a comfortable-sized rectangle. Try to keep it under 3/4".
Step 2: Form the "Blade"
Picture of Form the "Blade"
Lock your piece of wood in a vise or clamp it to a table. Make sure that about an inch of material sticks out to work with.
Use 60-grit sandpaper. Take the orbital sander to one side, sloping it to the edge. Alternately, use plain sandpaper to wear it down, or another sanding tool to achieve the same effect.
Flip the block over and slope the other side. The blade should be thick and stubby.
Starting on the first side again, make the slope gentler. Try to get the cross-section of the tool to look sharp and slender like a bullet.
Step 3: Fine Tuning
Picture of Fine Tuning
Remove your folder from pressure and hand-sand it on a flat surface.
Key things-
-Make sure the blade edge is level going across. Otherwise, it won't consistently crease your paper.
      -To get a level edge, hold the folder upright and push it into the table as you sand. Then re-sharpen the blade.
-Smooth the blade's corners so they won't mark paper.
-Move from 60-, to 80-, to 110-, to 220-grit and beyond. Wipe the folder between grits with a damp cloth so extra wood fiber sticks up.
-How sharp do you want this thing? Not sharp enough to be delicate, but not too thick to be effective...run some tests until you're satisfied.
Give most of your attention to the blade, because it needs to be silky smooth.
Step 4: Finishing & Application
Picture of Finishing & Application
If you like, find the center and drill a hole. I took the edges off the hole with a Dremel and sanding bit.
Thread a length of cord or chain through the hole, and hang it where it's handy.
I don't finish my folders in fear of stuff rubbing off onto my paper. With use, the edge will get shiny and seasoned. Make sure to keep it clean and true, using light sandpaper to smooth down any problems.
To use your new flat folder, score a line in your paper (or book signature), fold over and belly the paper at the score line (without creasing it), and hold the paper edges down while you drag the folder over the score line toward you.
I must recognize Aldren A. Watson of Hand Bookbinding for the original idea, and for including handmade tools in his book anyway.
Enjoy!
About This Instructable
2,355views
7favorites
License:
Bio: I'm in Austin, Texas, enjoying the Greenbelt, the libraries, the food, and the people. Thanks to all you out there who help me learn ... More »
More by Kim Neely:Log Cross-Section Relief Sculpture WIPLimit Your Paint Palette with Digital Gamut MappingFlat Folder for Papercrafting
Add instructable to:
