Introduction: Flat Panel HDTV Antenna
Picture of Flat Panel HDTV Antenna
This guide will tell you everything you need to know about how to
assemble and install your Flat Panel HDTV Antenna from FoxSmart.
Step 1: Unbox and Identify Components
Picture of Unbox and Identify Components
Remove all components from the box. You should have the following (clockwise from the top):
  • Antenna (1)
  • Double-sided tape (4)
  • Stand
Step 2: Stand
Picture of Stand
After unboxing your antenna and components, unwrap the stand and position antenna into the grooves.
Note: if desired, our antenna can also be used as the perfect finishing touch on your Tron Man costume.
Step 3: Connect Coax Cable to TV
Picture of Connect Coax Cable to TV
Plug the AC adapter into your wall outlet. Plug the coax cable into the 'video in' or 'antenna in' port on your TV.
Step 4: Scan for Channels
Picture of Scan for Channels
Once installed, turn your TV on. Go into your TV's 'settings' menu, then select the 'scan for channels' option. It may take several minutes for your TV to scan for all available channels. Once completed, you should have access to local broadcasting stations like CBS, NBC, OETA, etc. Check FCC.gov for a full list of channels available in your area.
Congratulations! Now you have access to free local TV channels.
Step 5: ...wait, Free TV?
Picture of ...wait, Free TV?
Yes. Now that you've installed your antenna, you've taken the first step toward a life without cable bills and 6 hour tech appointment windows. Complete the process by picking up a streaming media player (we like Apple TV or Roku) and a subscription to Netflix, Hulu, Amazon Prime, Crackle, and other streaming services. Think of your friends at FoxSmart as you enjoy your $1000+ annual savings after you've cut your cable. We hope you're enjoying your free TV as much as this family is. Got questions about cutting cable? Check out our free cable cutting guide.
About This Instructable
1,266views
0favorites
License:
Bio: We love instructables. We make and tear up and improve and sometimes destroy. Some of this are instructions for use of our products. Some of ... More »
Add instructable to:
