Step 3Cut out your pattern
iImage Information
Place your first layer of felt right-side-down on a flat surface. Then the other piece of felt right-side-up on top of it and the pattern on top. If the pattern is small (less than a square foot) you can just press down on it or use a couple pins to keep it in place while cutting. If the pattern is larger, you'll need to baste all three layers together with the contrasting button thread (you'll remove this later). However, make sure you leave enough room to insert the zipper (probably about 3/4") all the way around the edge. Cut out your pattern on the inner line and use your knife/rotary cutter to cut out the handles.
