Flat-pack Light Play Box
1,952
22
Posted in TechnologyArt
Introduction: Flat-pack Light Play Box
The Tinkering Studio at The Exploratorium in San Francisco has a wonderful light box tinkering activity. You choose objects that cast interesting shadows, arrange them behind a translucent screen, and shine a small bright light on them. Place some of your objects on a slowly turning motor (blend door motors scavenged from junkyards are the best!) and the results are mesmerizing.
Here is how I built an inexpensive light play box that packs flat when not in use.
Materials:
  • a large, sturdy cardboard box with a display window. I got my box from Costco. Its about 23" x 12" x 15"
  • a 21" x 30" sheet of mylar from the art supply store. I had to buy a 42" x 30" sheet and cut it in half. It was 0.004 mm thick and double matte. I think white butcher paper might work as well.
  • 12 brass brads (they are used to fasten papers- look in the office supply section)
Step 1: Punch Holes for the Brads
Punch holes through each of the 8 corners of the box where the cardboard flaps overlap. I used an ice pick.
Step 2: Pry the Glued Flaps Apart
Pry all of the cardboard flaps apart. You will put them back together with brads. The flaps are hot-glued together. Use a sturdy tool!
Step 3: Cut Each Back Flap to Make Doors
Make a cut in each of the back flaps so that a “door” can be left open but the top corners can be re-fastened.
Step 4: Cut a Larger Display Window (optional)
Your light display will be more beautiful, but the box won't be sturdy enough to stack one on top of another.
Step 5: Re-fasten All the Cardboard Flaps With Brads
Step 6: Prepare the Mylar
Use a hole-puncher to punch holes in each corner of a 21"x 30" sheet of mylar or some other translucent material, even white butcher paper . You may need to cut the sheet smaller to fit inside your box.
Step 7: Insert the Mylar Screen
Place the mylar inside the box in a U-shape. Mark inside the box where the 4 mylar holes touch the cardboard, then punch holes into the cardboard. To attach the mylar to the box, put brads through the holes in the mylar and cardboard.
Step 8: The Finished Light Box
Find some things that cast interesting shadows and put them in the box. Shine a small bright light (I use an extra bright LED) on them and view from the front. Try adding another light, or colored lights. Put some objects on a slowly turning motor-spectacular! Try stacking two rows of boxes (as long as they are not too heavy)
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    3 Comments
    Dope flat pack assembly man! I can't believe all the cool flat pack projects I have found here! The last gif looks more than romantic! Really simple and easy flat pack assembly idea but yet super effective!
