Flat pack for storage Plywood Picnic Table
 by Gareth0123
Featured
These picnic tables are each made from a single sheet of plywood, take about 30 minutes to mark out, and about 1 hour to cut out. The sanding and painting is down to the individual, so I'll not quote any times for these two processes, but I have finished mine with a combination of wood preserver on the undersides and gloss paint on the topsides .
A short video of me assembling and disassembling one of my picnic tables: http://www.youtube.com/watch?v=xATfmOkLh7Q&list=UU1iX9q83W978_o37wLxqkvw&index=2&feature=plcp
You will need a copy of the plans, which you can download and save from here:
http://familyfun.go.com/crafts/picnic-table-to-go-709134/
To mark out the plywood, you'll need: a rule or tape measure, a pencil, a square, and a straight edge of about 4 feet long, or slightly longer; a planed 4 X 1 piece of timber just over 4 feet long, or a length of steel are ideal.
I have used a cordless jigsaw for the rounded cuts, and cordless circular saw for the long straight cuts, but a jigsaw will be more than adequate for all the cutting requirements.
Pay close attention to the plans, as they follow both a Centre Line set of dimensions, and Accumulated dimensions from the bottom edge of the sheet of plywood. The only really tricky part of the plans and the dimensioning is ensuring that you follow the accumulated dimensions correctly and mark out accurately.
Note: I have used 18 mm thick shuttering plywood rather than the recommended 1" thick plywood: so if you follow my lead here, you'll need to reduce the joint let ins from 1" to 18 mm.
Step 2: The cutting order.
Start by cutting in this order; if you begin with the long straight cuts, it will reduce the sections of plywood to a more manageable size:
1) Cut out the table top.
2) Cut out  the seat supports
3) Cut out the seat tops
Step 4:
Then cut the main central support from the sheet, followed by the table ends.
Step 5: This step is optional:
Cutting out additional hand grip points is optional; only 2 of my 6 picnic tables have these additional hand grips in the table ends.
In my opinion they are not necessary near the top of the table end, but would be better placed lower down the panel.
I have used a 2 inch diameter holesaw and a jigsaw to cut out the hand grips.
Step 6: Time to cut out the slip joints
Now it is time to cut out the assembly slip joints. As previously mentioned I have used a sheet of 18 mm thick plywood to make my picnic tables, so I have to cut the joints to suit.
Step 7:
I have not shown the carrying bracket that is on the original plans; I found this awkward and cumbersome to use, so I now use a couple of webbing straps with a clam action clasp to keep the table components together when they are being handled and stored.
Here is a link to the additional instructable on how to make the additional feet for the picnic tables shown in the photo:http://www.instructables.com/id/Additional-feet-for-Picnic-tables/
I painted two of my six  tables bright yellow to use at the many shows and festivals that we attend, but that was a mistake as it attracts many flying insects. We now have them painted a more subdued  gloss Yellow (Ral 1028) which does not attract the insects. The Cargo Cycles logo and contact details have been applied to the table top, which has turned out to be a rather good way of making the public aware of my business .All six flat pack plywood picnic tables and two 25 X 10 marquees fit into the back of one of our electric assist Pedi-vans with room to spare .... a great way to haul stuff around the on the show grounds and festival sites.
kevinhannan says: May 16, 2013. 11:11 AM
Very nice indeed.
However I cannot find the plans and have trawled through the website link. If I get to see the plans I shall certainly have a go at this fine 'ible.
Gareth0123 (author) in reply to kevinhannanMay 18, 2013. 3:07 PM
Hi Kevin,
If you scroll down to the bottom of this web page, you will find a (free) downloadable PDF version of the plans http://overthegate.myfreeforum.org/sutra268083.php#268083
allen.curry83 says: Feb 2, 2013. 11:23 AM
The link to the blueprints does not load properly does anyone have a copy I NEED THEM ... PLEASE! thanks allen.curry83@yahoo.com
DeanAshby says: Jan 21, 2013. 12:09 AM
Pure genius! A full plywood picnic table that can take so little space in storage! Just a question, is it possible for me to use MDF board for this? Reason I ask is because I have loads of them in storage (after a workshop closed down near my house) and I would love to use them for something good.
mganpate says: Aug 9, 2012. 1:49 PM
super idea iwill make ...
Thanks
matt.nupen says: May 19, 2012. 11:32 AM
The pdf link is broken, here's the url of the new address
Gareth0123 (author) in reply to matt.nupenMay 21, 2012. 1:11 PM
Thank you for your comment about the broken link Matt.
I have now up dated the link on the main page of this instructable.
Regards
Gareth
Gareth0123 (author) says: Jan 17, 2012. 4:35 AM
Thank you to all for the nice comments, and especially to Skirmishmonkey for the photograph.
As mentioned in the original Instructable I now have six of these tables for use at the various shows and festivals we attend, and I replace two of the tables with new ones each year.The old tables are donated to my church's scout group for their use at camps, fetes and fund raisers, etc.
I have now slightly modified how I build the tables, using an off cut of ply wood and a 4 inch diameter hole saw to make a plywood plug which I quarter.This is glued and pinned in place under the table tops, and the seat tops. If you use this method under the seat tops the long cut out, and tenon are not required in the seat supports, and it prevents clothing being trapped in the slip joint gaps.
skirmishmonkey in reply to Gareth0123Jan 23, 2012. 12:40 AM
You are welcome.
Here is the finished item using yacht varnish (UV resistant, hard wearing and weatherproof).
I like the circular finishing and using the same for the bench seats. It is a simpler finish than the cut outs.
This was my first 'big' project and I am pleased with how well it turned out. Which is a testament to the extremely clear 'ible and great tips included.
TO others, if you haven't started yours yet, do it today.
skirmishmonkey says: Jan 17, 2012. 3:06 AM
Oops pic didn't upload last time. Here it is.
Thanks again.
BTW, I have had loads of excellent feedback on my build. I point everyone this way.
skirmishmonkey says: Jan 17, 2012. 3:05 AM
Great Instructable! I bought myself a circular saw and wondered what I could make with it. Saw this and was inspired. Here is a pic of my effort.
Now all that is left is the fine finishing and varnishing. I was thinking of painting but have been convinced to varnish it.
Thanks for the inspiration.
Tinkerteem says: Jan 14, 2012. 9:13 AM
beautiful design :)
wiglaf says: Jan 14, 2012. 7:58 AM
Great instructable! I'm seriously thinking of making one of these for my kids, and to use when camping. Would be cool if there were a way to make the feet height adjustable, in order to prevent the inevitable wobbling that occurs when it's placed on uneven ground.
Also, that "cargo cycle" is AWESOME!!! Do you have a link to the web site for it?
skiedra says: Jan 10, 2012. 11:07 PM
That is a very fine table!
snoyes says: Nov 24, 2010. 2:57 PM
Neat! Do you have a picture of one torn down and strapped together, and how you carry it?
Gareth0123 (author) in reply to snoyesNov 24, 2010. 3:05 PM
Good point;
Alas I do not, but I will take a photo of one of the tables flat packed and strapped tomorrow and then add it to the end of the instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
