Flatpack Folder
Introduction: Flatpack Folder
A folder is a big object, altough it could and should be smaller to transport. The biggest issue are the two rings. In this instructable I will prove it's possible to create a flatpack folder and show you how you can make it.
Step 1: Tools Needed
For this job you'll need:
- a drill
- a 3 mm and 4,5 mm drill bit
- a screwdriver
- pliers
- a calliper
Step 2: Materials Needed
To make this folder you'll need:
- a folder
- four 5 x 10 flat headed screws
Step 3: Remove Rivets
Remove the rivets using a 3 mm drill bit, there should be four of them. Use pliers to remove any remaining pieces of these rivets once you've drilled trough.
Step 4: Drilling Holes in the Mechanism
The mechanism has four 3 mm holes in it, use the 4,5 mm drill bit to widen them.
Step 5: Screwing the Mechanism in Place
Because we use screws with a diameter of 5 in 4,5 mm holes, you can bolt them tight in the metal of the mechanism.
Step 6: End Result
Your brand new folder is now ready to use. Thanks to this way of making a folder flatpack, you can fit about
48 of them in a box with dimensions 65 x 30 x 32 cm compared to 16 regular folders.
Instead of screws I would like to use a one-time click mechanism so it is much faster to assemble. Assembly and disassembly after the first time is less usefull anyway.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
