loading
loading
Picture of Conductive Fabric Pressure Sensor
Sew together conductive fabric and anti-static plastic to make your own fabric pressure sensor!
These step-by-step instructions will show you how to make your own fabric pressure sensor. It mentions two different variations, depending on if you use stretchy or non-stretchy fabric.
The materials used for the sensor are basically cheap and off-the-shelf. There are other places that sell conductive fabrics and Velostat, but LessEMF is a convenient option for both, especially for shipping within North America.
Velostat is the brand name for the plastic bags in which sensitive electronic components are packaged in. Also called anti-static, ex-static, carbon based plastic... (So you can also cut up one of these black plastic bags if you have one at hand. But caution! Not all of them work!)
To make the sensor fully fabric one can use EeonTex(TM) conductive textile (www.eeonyx.com) instead of the plastic Velostat, but at the moment EeonTex(TM) conductive textile is only available in a minimum of 100yds.
This is an improvement on the Flexible Fabric Touchpad Instructable, using "iron-on" and plastic ex-static instead of the fabric which is less stable in maintaining resistance between the two conductive layers.
To see what we use this technology for visit:
www.massage-me.at
www.plusea.at
www.kobakant.at
VIDEO
Step 1: Materials and tools
Picture of Materials and tools
MATERIALS:
Stretchy version:
- Cotton jersey
- Stretch conductive fabric from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/stretch_conductive_fabric
- Fusible interfacing from local fabric store
Non-Stretchy version:
- Cotton
- Shieldit conductive fabric from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/shieldit_super
it already comes with heat glue fused to one side
Both versions:
- Velostat by 3M from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/velostat_resistive_plastic
- Thread
- Machine poppers/snaps
TOOLS:
- Pen and paper
- Ruler
(- Compass)
- Scissors
- Iron
- Sewing needle
- Popper/snap machine (hand held or hammer and simple version)
1-40 of 86Next »
NelsonN222 days ago
any way to make this waterprooff???thanks you guys
There are links to vendor sites, but no links to the actual products used. On the lessemf.com site, the term "stretch conductive fabric" is not even found. Can you be a little more specific regarding the fabric or part numbers? Thanks
jwakama6 months ago
Hi guys wanted to ask, what is the principle behind this sensor working. Maybe ohms law being applied? just curious. Thanks
eklypz1 year ago
Do you happen to have any suggestions on how to make this waterproof? I would like to use this to put sensors around a dance floor that people step on and interactively control neopixels or some other lighting effect but think the fabric would get tore up or drinks spilled on. Thanks for any advise!
richddt1 year ago
I'm also interested in making a larger one, about 19" x 9". Did you determine if the resistance changes? I'm just looking to make a switch, so perhaps there's an even easier way to do it.
billlavin2 years ago
I would love to know if anyone can help me here.... I want to find a senser for persperation fabric company that makes these kinds of fabrics so I can contact them for a special project I am working on... my e-mail is: bill.lavin@verizon.net Thanks so much...
lnorooz2 years ago
Tooootally awesome!
I've got a question for you. I want to do this on a slightly larger scale. If I wanted to make this in the dimensions of around 3x3 feet, how would that affect the resistance? Would I have to push down harder to get it to work? Also, how would a 6x6 feet piece of this work? Would it be twice as hard when I push down on it?
mrmerino2 years ago
Could I rotate the connectors so they're closer to each other?
Plusea (author)  mrmerino2 years ago
yes, sure! just make sure the conductive opposite sides of conductive fabric never touch each other directly. only ever through the velostat.
great job.
freak883 years ago
Hey. This is great! I was planning on purchasing this pressure sensor. Just had a few questions -
1. What is the range of force that it can measure? ( If analog values of the force can be tapped from it at all!)
2. Can the surface area be made smaller?
3. Does the pressure sensing work on both sides of the material?
Thanks in advance :).
TSLoire3 years ago
Wow Plusea this is awesome! Infact it's just what I have been looking for! A few questions if you'd be so kind to answer?
Firstly, instead of using batteries as a power source, would it be possible to use a USB power source? For example, you plug such a device as this into the PC using a standard USB cable?
I am creating a touch sensitive project right now and I think this design is awesome, if it would take power from a USB connection then I'd be hooking up the wires to pins on a U-HID G board (http://www.u-hid.com/home/uhidg.php) and using the touch/pressure as input. Any ideas on whether this would be possible or not?
Thnaks, I'm going to have a gander at your other projects =) Hope to hear from you soon!
hazykev TSLoire3 years ago
That's totally possible - USB is runs at 500mA &has 0V & 5V pins so it's possible to use it as a power supply for all kinds of things, provided of course the G board (which I'm not familiar with) will work @5V, <500mA
rmohamed13 years ago
hi..first, i would like to say that ur idea is really cool..n amazing..
anyway, o want to make something similar, but cant find the materials here.im in Malaysia..would you know of the closest place i could find something suitable..any alternative?
awaiting ur reply..
thanks
spost4 years ago
Great work! I think that your device may be helpful in a project I am working on. I am trying to find a pressure sensor that can monitor the pressure between a child's heel and a cast. That is, if the pressure becomes too great, parents are signaled by illumination of the bulb and the child can be repositioned etc. A couple of questions: 1) Do you think your product will work for this application? 2) I would need to minimize things like alligator clips close to the sensor as they would be in the cast and potentially harmful to the patient's skin. So, is it possible to extend the "wings" so they would be outside the cast? 3) Casts often stay on for many weeks. Are the materials durable enough to hold up?
Thanks so much!
Plusea (author)  spost4 years ago
for sure you can extend the tabs, you can also replace the alligator clips with strips of conductive fabric or thread. i think the challenge will be to calibrate the pressure sensor to detect what is too much pressure and compensate for any change in the sensor range that would occur over time and under constant pressure. but i think it would be possible and would love to see what you make!
Hlias4 years ago
Very good instructable indeed. Congratulations and thank you very much for your post.
I just finished making the pressure sensor successfully and i tried to connect it to a small circuit, in order to control a small coin-type vibrator. What happened when I connected the vibrator, was that even without pressing the switch, the vibrator went on (although not very strong) while when I pressed the switch it vibrated more intensely.
I would like the switch to be like on/off type (hence switch). What I realized is that the resistance provided by the sensor is very low (around 130 Ohms as I measured it) and thus permits current flowing even when in the "off" position.
Is there any solution to my problem (like a small circuit maybe with a transistor)?
Plusea (author)  Hlias4 years ago
good question. the resistance of the pressure sensor depends very much on the construction. if you manage to sandwich and sew it together really loosely you can sometimes create high enough resistance for vibration motors and LED lights to appear 'off'. but not wanting to rely on loose construction is probably a better way to go and the easiest solution i see is to combine the pressure sensor with the fabric switch - so add a layer of perforated foam in between one side of the velostat and conductive fabric! the layer of foam will insure that there is no contact unless pressured and then when pressured the pressure sensing properties of the velostat will apply.
fabric button >> http://www.instructables.com/id/Three-Fabric-Buttons/
lanehogenes4 years ago
I have a simple question. What is the fusible interfacing material exactly? Is there a name for this product that I can go search for? I'm just not sure exactly what this stuff is and what it does. Is it a conductive fabric? Thank you for all your great help!
Plusea (author)  lanehogenes4 years ago
here is a link to a description of what fusible interfacing is:
http://www.fabriclandwest.com/Notion_basics/Interfacing/interfacing.htm
it is basically a thin sheet of glue that melts when heated by the iron and is intended to "fuse" (=glue) two layers of fabric together.
Thank you!
Sapas_4 years ago
Hello everyone.
I'm currently working with a velostat equivalent, Linqstat, from Caplinq. Does anyone have a suggestion on how to characterize this material? Electrically, I mean.
Thanks in advance!
Plusea (author)  Sapas_4 years ago
Linqstat is basically identical to Velostat (they are just two different brand names). They are both carbon infused polymers and have "piezo-resistive" electrical properties.
caplinq4 years ago
Hi Plusea - We have some people asking which hot melt adhesives work best with the Linqstat / Velostat material.
Knowing that you probably have more experience than anyone with bonding and working with these materials, I was hoping you could provide some guidance.
Plusea (author)  caplinq4 years ago
i've actually experienced that heat ruins the piezoresistive properties of velostat.
so i would tend to recommend double sided sticky tape instead.
caplinq Plusea4 years ago
Thanks Plusea - yes, the softening temperature of the Linqstat is around 85C, so I would agree that if a hot melt is used, that the temperature of the hot melt is less than the softening temperature of the Linqstat.
drummerwei4 years ago
Hi, I am a graduate student in Taiwan. Your Idea is really AMAZING, I LOVE IT ! Would you mind I ask you some question about the Velostat. Can you tell me the Velostat datasheet, Thickness and Resistance Value ? Because I have found the Velostat in Taiwan, but the Resistance was too high approaching 1 x 10^7 ohms, it is very hard to used.Or maybe I can use some conductive foam according your method?I'm just confused on the resistance. Hope you can help me to solve this problem.Your help and early reply will be appreciated. I am looking forward to hearing from you soon.
Plusea (author)  drummerwei4 years ago
i use the brand products velostat (3m) and linqstat (caplinq) and these have a good resistance range. from K ohm to hundred ohm. here is my post on velostat: http://www.kobakant.at/DIY/?p=381
andresjv224 years ago
HI PLUSEA!! Excuse me, I want to make your pressure sensor, but I have some questions that stop me... 1. In this one you actually don't use a conductive thread, do you? 2. The conductive fabric is a special one? Or maybe with nylon o polyester that produce static is possible? 3. Would you say that without Velostat or that kind of bag, this experiment is impossible? I'm surprised because first of all, isn´t that material specially not for conduct? Why with pressure it changes? Congratulations for your work and thanks in advance for your answer!!
Plusea (author)  andresjv224 years ago
i'm not quite sure i understand everything you are asking. but will try to answer. please ask again if i am still not clear. you can use any kind of conductive material on either side of the velostat (piezoresistive material). but the more conductive the material is, the less range you will have. that is why in later versions i switch to using conductive thread - to minimize the conductive surface area. the velostat or any other piezoresistive material is key to this pressure sensor working.
kewlkat0075 years ago
 i love this you could take this next level and make bracelets if  you you configure some type of batery pack or some thing in there like lilly pad but any ways this is great already made one
knektek5 years ago
lol. Put this on your sofa, when you sit down it will light up. Now that will explain the wall wart coming out of the sofa.....
zigzagchris5 years ago
I see it now. underwear that weighs you when you sit down. Mabee it could incourage weight loss?
zyzar5 years ago
Hi
I would like to know that can it be tested with 1.5V battery with simple LED??
Plusea (author)  zyzar5 years ago
if you have an LED that lights up with a 1.5V battery (without pressure sensor), then it might. otherwise put two 1.5V batteries in series or use a 3V coin-cell battery and this should definitely work.
if you connect it all together with the sensor and the LED is always on, then it could be that your pressure sensor is so tight that the initial pressure is already enough to decrease the resistance of the velostat to fully power the LED, but this does not mean that your sensor does not have any range. just that it is the wrong range (too low resistance) for the LED.
hope this helps.
bartens6 years ago
Hi can anyone supply me with 6 of thos wonderfull flexible fabric pressure sensors? I have tried myself but cannot get hold of the right material here in The Netherlands, Europe. If someone can help me get the right fabrics this might help too.. Thanks
caplinq bartens5 years ago
You can buy LINQSTAT (equivalent 3M Velostat material) directly from our website and it ships from either our Ottawa, Canada or Amsterdam Netherlands warehouse depending on where you ship to.
http://www.caplinq.com/linqstat-vcf-s-series-linqstat-volume-conductive-film.html
Plusea (author)  bartens6 years ago
I'd be happy to send you some. I'm also selling be happy to send you some. I'm also selling Fabric Bend Sensors via Etsy >> http://www.etsy.com/view_listing.php?listing_id=14491554
Regarding finding conductive fabrics in Europe... I'm looking into it. But LessEMF also ships to Europe.
1-40 of 86Next »
