Remove these ads by
Signing UpStep 1Materials
(The amounts of material depend on how large you want the touch pad to be)
- Ex-static fabric from www.lessemf.com
(also see http://cnmat.berkeley.edu/resource/ex_static_conductive_fabric)
- Stretch conductive fabric from www.lessemf.com
(also see http://cnmat.berkeley.edu/resource/stretch_conductive_fabric)
- Cotton thread or a kind of non-conductive adhesive
Optional:
- Another material as padding on either side. In the example I'm using Neoprene (ordered from Sedochemicals)
- An LED to show it works
- Energy source. In the example I'm using 3x1.5 Volt batteries
- Cables to connect
and MUTR in england >> http://www.mindsetsonline.co.uk/index.php?cPath=418_6_572
>> http://www.kobakant.at/DIY/?p=65
Thank you
I want to make ti the size of a standard "Welcome!" mat.
Is there a difference?
also, this is a rather old Instructable, be sure to look at some of the newer designs:
>> http://www.instructables.com/id/Conductive-Thread-Pressure-Sensor/
>> http://www.instructables.com/id/Pressure-Sensor-Matrix/
>> http://www.instructables.com/id/Flexible-Fabric-Pressure-Sensor/
if you are you are using "wire" and not conductive fabric or thread for the long (how long?) connections then you should be fine.
also check out the following instructable:
>> http://www.instructables.com/id/Conductive_Thread_Pressure_Sensor/
i've had better results with the velostat (or eeonyx fabrics) than the ex-static fabric.
ive actually done some more recent versions of this pressure sensor. you can see pictures of them here: http://flickr.com/photos/plusea/sets/72157607328386559/
and this is a similar Instructable: http://www.instructables.com/id/Analog-Fabric-Joypad/
since these more recent versions use stitches of thread, rather than a full surface of conductive fabric, i could imagine stitching in such a way that allows quite a lot of transparency. neoprene and other squishy materials are great for the force feedback of a pressure sensor. one could also use silicone or rubbers. as for the layer of Velostat/piezoresistive material inbetween... i'm not sure of a transparent version of this. there are ways one could also cut holes in this to make it somewhat transparent.
i'm actually located in both america and europe so that i order things from the US to my american address. i don't know how long it takes to europe, but i would expect them to be quite fast, not more than a week or 10 days.
what are you working on? i'd be interested to see some pictures.
good luck and fun!
i was also thinking maybe if you set 3 or 4 points where you meassure the current flowing then you could do a callibration by pressing on different points of the surface and saving the different (if they are different) results from each of the points and then in future you could track where the preassure is being appied by comparison.
what i like about this touch pad is that both how hard you press and how much surface you cover influences the resulting current.
i want to implement it in future in a "massage gamepad" http://plusea.at/mme.php because inbetween the layers of neoprene it responds nicely to both light touch over a large surface and strong pressure applied to small areas.
I am looking into this topic for the creation of pressure sensitive mats which I can place in the desert sand next to some surplus company assets which are being stolen for their scrap or salvage steel weight, at about 11 to 1,200 pounds each. So I create these mats, from a rubberized, water and element proof material, and place them and cover them over with about an inch of sand -- and when a criminal approaches their target to hook it up to their portable hoist -- they compress the mat and complete the circuit = which is connected to either a loud siren and intense strobe light, etc. Or even some sort of non-lethal concussion device which is also buried in the sand next to the asset, and with respect, either the Security personnel is alerted by the noise, and or, the bright light(s) -- or the criminals can no longer perform their work on the private property in which they have NO UNDERSTANDING of the concept of; *Keep Out* *No Trespassing*, etc. = so they stumble away trying to figure out what just happened to their sorry butts.
Now, I would normally go with an attached trip-wire to set off one or the other types of support devices -- but the difficulty there is in lifting the asset and finding a place to tie the wire up in a way in which no one can easily see it and disarm it before moving the asset; so the pressure mat does Not have to be attached, and can be completely covered by the natural desert materials, and can be placed where the criminal can't even lay his hands on the asset before setting OFF the switch that completes the Security protection circuit. And on the other side of the coin; the circuit can trip a Silent alarm which brings me out to make the Arrest while they are still working on their theft. That one is my favorite, over circuits and systems that will only scare them off. The Arrest(s) make more noise on the local news and has the possibility of warning other criminals or crews that the risk of capture is just too great in a particular territory.
So there ya go. An example use of the concept, if not the actual materials mentioned in this article. I'll most likely locate, or create my own conductive materials for the pressure mats I require to put a stop to the near constant criminal attacks in my territory. Any existing products already on the market are absurdly over-priced which knocks those sellers right out of our security budget.
Thanks for your time.
Does that make it any clearer???
http://xyinteraction.free.fr/wiki/pmwiki.php/Site/Concept
I'm personally starting with hardware, but moving on to fabrics very soon by the looks of it.
We also ordered sample kits from a few Chinese companies, that arrived but did not contain a stretchy conductive fabric.
And yes again to wire connection. So far the best result has been to use iron-on sheeting (a kind of fabric glue) to connect the wire to the conductive material (sandwiched between), but it is not really optimal. We've now got some samples of conductive thread from www.bekaert.com and want to see what other solutions we can come up with.
We had problems with the resistance over a large (about A4 size) surface with some of the other kinds of conductive material, but not with the stretch-conductive so far.
