Introduction: Flexible Magnet Shaft for Better Lighting With Tools Made at Techshop
Problem:
some tools have shadowed ares that would benefit from more directed light.
Solution:
magnet attached flexi-light
Materials:
magnet
flexitube
super glue
duct tape
flashlight
Step 1:
buy a flexible shaft
this was the only thing my local harbor freight had, but you can use anything that flexes
Step 2:
It looks like the magnet will fit on the threaded end
Step 3:
Modify the threaded end to barely fit the disc magnet
use a micrometer to measure the width of the magnet and match with a drill bit
Step 4:
Attached female end to male, threaded part and cut to depth of magnet
Step 5:
Magnet fits tightly and superglue holds it in
Step 6:
This double sided tape would not hold the magnet in, learn from my fails.
Step 7:
Squishing the magnet in place didn't work
Step 8:
Attach the flashlight to the flexible cable.
I used tape, but you could spot weld it, use stronger tape, etc.
Step 9:
I tried stainless steel cables, but it was too loose
Step 10:
Test final prototype
Yea, it works
I couldn't find a battery powered, magnet mounted, flexible light, that was strong enough on amazon, so I made one.
I made it at TechShop
http://www.techshop.ws/
