Step 2: Circuit diagram
complete the circuit according to the circuit diagram,here i have used a common circuit board, there is a simple way to find the polarity of the LED ie, by looking for the flat part in the diameter of the LED the leg in that side will be negative
clayman987 says: Feb 11, 2013. 12:50 PM
I am wondering are the transistors 3904 or 2N2222A because all I have is 3904. And for the 390 ohm resistor can I use 330 ohms, sorry I don't have many parts!:)
Mudbud in reply to clayman987Mar 12, 2013. 4:28 PM
Those should work, as long as its NPN, (to an extent)
jimmy558 says: Mar 6, 2012. 4:29 AM
can i operate this with aproximately 7 volt battery??
sooraj619 (author) in reply to jimmy558Mar 6, 2012. 5:36 AM
yes
jimmy558 says: Feb 20, 2012. 6:09 PM
what is the timing of leds turning on & off...??
sooraj619 (author) in reply to jimmy558Feb 21, 2012. 8:46 AM
about 1 second, you can increase or decrease the fading effect by changing the values of both the capacitors
kyooby says: Dec 6, 2011. 10:57 PM
thank you.i remember toose days when i maded this stuffs.cool
sooraj619 (author) in reply to kyoobyDec 9, 2011. 6:52 AM
thanks
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
